Not so good vibration - JeepForum.com
post #1 of 15 Old 08-03-2015, 08:40 PM Thread Starter
carnell
Finished a AX-15 conversion to my 86 CJ7. I've now noticed that at 15 mph and between 35 and 45 mph I get a decent vibration. Same thing if I'm decelerating. The vibration goes away once the clutch is in (at the above stated speeds). Could my new driveshafts (original but modified for shorter length) be out of balance? If thats the case, going at the above speeds even with the clutch in, there still would be a vibration right?
Chappy
Before the mod, my T176 was super smooth. I hate to say it but I kinda miss it
carnell is offline
post #2 of 15 Old 08-03-2015, 10:00 PM
Mikey37
2005 KJ Liberty
Well I am not a pro but I will chime in and hope it helps. I think driveshaft moves as your wheels do so I would think that it would be felt at all times, maybe get worse with speed? (not the drug) lol .... sounds like you know more than me about this kind of thing so I imagine you checked usual suspects (tires bearings rotors etc) and if so then all I can say is good luck and someone will chime in with more knowledge than I. I am a simple back yarder going on limited experience and a bit of common sense lol of course if your shaft was modded then it's likely out of balance or at least get it checked...
Professionals built the Titanic, amateurs built the Ark.
Mikey37 is offline
post #3 of 15 Old 08-03-2015, 10:33 PM
BagusJeep
1981 CJ7
Out of balance driveshafts or worn out U joints or driveshafts assembled with the slip joint misaligned, such that the centreline of the joints at each end are not in the same plane.
Is it lifted at all?
When they wer changed in length, did you have them rebalanced?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 15 Old 08-03-2015, 11:53 PM Thread Starter
carnell
I have a 3 in lift. The rear & front both were cut to size, rebalanced with new U joints. I haven't used it in 4wd yet so all the vibes I'm feeling are while driving 2wd.
I don't remember how to check the plane??
I can call the driveline shop tomorrow and ask them to rebalance it. Not sure how they could mess that up.
Chappy
carnell is offline
post #5 of 15 Old 08-04-2015, 06:02 PM Thread Starter
carnell
Bump
carnell is offline
post #6 of 15 Old 08-04-2015, 07:21 PM
Mikey37
2005 KJ Liberty
Chappy
Mikey37 is offline
post #7 of 15 Old 08-04-2015, 07:22 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Since the vib goes away with the clutch in, it's most likely related to torque on the engine/driveline.
Have you checked your engine and trans mounts?
Matt
Matt1981CJ7 is offline
post #8 of 15 Old 08-04-2015, 10:51 PM Thread Starter
carnell
Matt
Trans mount is new and was done when I installed the transmission. The engine mounts are about 7 years old. I did remove the PS mount last month when I dropped my oilpan.
One thing worth noting, even though I hand the engine supported with a jack, when I removed the PS mount, the engine dropped a bit even though the DS mount was still connected. Could that have started my issue?
I only drove it once with the new transmission before I replaced the oilpan gasket.
carnell is offline
post #9 of 15 Old 08-05-2015, 02:12 AM
Matt1981CJ7
1981 CJ7
I'd put the Jeep on jack stands, run it in gear, and look for the source of the vibration.
Matt
post #10 of 15 Old 08-05-2015, 07:39 AM Thread Starter
carnell
Matt
Good idea!!
I'll give that a shot over the weekend and see what I come up with. Thanks for the idea.
carnell is offline
post #11 of 15 Old 08-05-2015, 08:20 AM
LumpyGrits
Cj
Did you remove the slip spline during this install?
The DS might be out of 'phase'.
CK for play in the 'joints' and s'spline.
Grease them too.
What was the difference in length between the 2 tannys?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #12 of 15 Old 08-05-2015, 08:35 AM Thread Starter
carnell
Grease them too.
LG
I know the DS was ballanced once it was re-sized. Joints are tight and new. The new tranny is a bit longer so my rear shaft was cut shorter. Don't remeber the numbers...
carnell is offline
post #13 of 15 Old 08-05-2015, 11:39 AM
LumpyGrits
Cj
To much angle on the DS then.
May have to go to a double carden type u-joint deal.
The top DS in the picture is what I speak of.
http://www.pirate4x4.com/tech/billav...t/DCP_6524.JPG.
You could also try rotating up the rear pinion 2-3* with shims under the axle spring pad.
LG
post #14 of 15 Old 08-05-2015, 12:13 PM Thread Starter
carnell
That's about the size of my new DS. I'll contact the shop and get a price.
carnell is offline
post #15 of 15 Old 08-15-2015, 04:27 PM Thread Starter
carnell
The vibration is gone! The transmission got dropped an inch so the twin sticks could fit and that alone, took away the vibes.
carnell is offline
