Not a good day - JeepForum.com
post #1 of 31 Old 04-23-2013, 09:08 PM Thread Starter
caseypotts
1980 CJ7
Not a good day
So I changed a few few lines and added an in line filter. Got the jeep back together and fired it up. Everything looked good so I closed it and thought it take it for a quick spin. It backfired, the seconded it did I know it was on fire. It took a second to get the hood unlocked and the hood latches off, I was calm, I grabbed my fire extinguisher when I left the cab and had it shaken and the pin out before I opened the hood. Pretty good size fire down by the starter and around the carb. Lost some wires for sure. Oil pressure tube...fuel lines, not sure what else. Little bummed 400 miles on a new motor and a bunch of build. Kind of defeated.
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #2 of 31 Old 04-23-2013, 09:23 PM
TW80CJ5
1980 CJ5
Sorry to hear that buddy...
Beyond a few minor burns, cuts, and a busted knuckle or 10, I have been luck on my 80 Cj5 rebuild.
Keep the faith, you will get it figured out, and the most important thing is you didnt kill your Jeep, or yourself.
Not sure if this helps you but keep on keepin' on!
TW80CJ5 is offline
post #3 of 31 Old 04-23-2013, 09:25 PM
lucdog
lucdog's Avatar
1980 CJ5
That sucks , it does sound like you got the fire out without major damage. So good on you for that.
Any ideas on what caused it? I also curious how it got from the carb (if that was the origin of the fire) down to the starter. Fire usually go from the starting point, and up.
A couple questions if I may.
Do/did you have a hard line from the fuel pump to just before the filter?
Plastic or copper line for the oil pressure gauge .
Good thing for the Fire extinguisher.
Bill
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 31 Old 04-23-2013, 09:30 PM
MountainHound
1979 CJ7
I went through some tall water too fast in the middle of nowhere a few years ago. Fan sucked into radiator drove it home lost a cylinder, warped head etc.. Keep on truckin'
MountainHound is offline
post #5 of 31 Old 04-23-2013, 10:27 PM Thread Starter
caseypotts
1980 CJ7
Oil line is plastic but it is ran through a small vacuum line to protect it. Burnt off right at the nipple as it enters the engine.
Fuel lines are stock as far as I know. Rubber after the pump to the carb with a in-line before the carb. I also replaced the filter inside the carb today. There wasn't one.
My guess is that it flooded out. The line that an between the carb and the charcoal canister was crap and on the list of things to replace. I think it flooded and was able to get around that line and drip into the engine bay....down towards the starter.
It doesn't look to bad. Couple of burnt ground wires and the oil line. I'm sure I will be elbow deep in it again tomorrow. I sale the POS if it wasn't so much fun to drive!
Her Ride
post #6 of 31 Old 04-24-2013, 06:55 AM
lucdog
lucdog's Avatar
1980 CJ5
OEM is a hard line from the top of the fuel pump , over the top of the valve cover, then to the filter. A 2 or 3" piece of rubber fuel line is then used to connect to the filter.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #7 of 31 Old 04-24-2013, 07:25 AM
243
1978 FSJ Cherokee
You saved your CJ7 from a full out car-be-que and you are bummed out???
Bud, the glass is half full not half empty and I think you should celebrate
Post some photos, I would like to see your tweaked GM151
Dave's 78 Build
243 is offline
post #8 of 31 Old 04-24-2013, 07:27 AM Thread Starter
caseypotts
1980 CJ7
That must be for a I6. The 151 has the pump and the carb on the same side with the pump sitting about a foot away and below the carb.
Her Ride
post #9 of 31 Old 04-24-2013, 07:35 AM
lucdog
lucdog's Avatar
1980 CJ5
O. Ok didnt check your profile, looks like 243 did though.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 31 Old 04-24-2013, 07:40 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Is that a Rochester Carb?
John Strenk is offline
post #11 of 31 Old 04-24-2013, 08:25 AM Thread Starter
caseypotts
1980 CJ7
Yes it is. Rochester Varajet II.
Her Ride
post #12 of 31 Old 04-25-2013, 07:28 PM Thread Starter
caseypotts
1980 CJ7
Got most of it put together today but couldn't get it to start. Not sure if it is a water issue from putting out the fire and cleaning off the extinguisher dust or it is flooding. Had to go to work before I had time to dig too deep into that. Still have some wires to replace but it looks promising.
Her Ride
post #13 of 31 Old 04-25-2013, 07:44 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by lucdog View Post
Good thing for the fire extinguisher.
Ditto that! You probably prevented a great deal more damage by having the fire extinguisher!
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #14 of 31 Old 04-28-2013, 10:04 PM Thread Starter
caseypotts
1980 CJ7
It is back alive! Few more parts to replace and a wire or two that needs to be sliced but it runs! Little bit of extinguisher juice and water shorted out the alternator relay so it isn't charging so that will need to be replaced and I then i think I'm back in businesses!
Her Ride
post #15 of 31 Old 04-28-2013, 10:12 PM
Cj5Betty
1981 CJ5
Good work! Way to turn a bad day around in just 4 days. Sounds like it could have been a lot worse. Good luck on finishing her up.
Fab your way to victory!
Cj5Betty is offline
