not enough suspension travel??? - JeepForum.com
post #1 of 11 Old 02-16-2012, 02:08 PM Thread Starter
chevypowered
1981 CJ7
Hey guys just wondering if any of you had this problem or if theres a kit out there that would take care of this. I have a 1981 cj7 with a 4" lift, most of the places i wheel are rockey so flex is a must. It just seems that i should be able to get a lot more flex then I'm getting now. When it is flexed all the way the shocks seem to be restricting it from going further both up and down. I double checked the shocks and they seem to be the correct ones. Any thoughts or ideas?
chevypowered is offline
post #2 of 11 Old 02-16-2012, 02:54 PM
CJ7Sasquatch
1979 CJ7
If you think the shocks are hindering your travel, take em off and the go flex it out, measure the compressed side and extended side both front and back, then that gives you a basis on the true length you need, most lifts out there give you to short of a shock, could also be bump stops, do you have bump stops? I don't run bump stops and mine flex's great, course it's soa but I plan on atleast putting in limit straps
ECV 1864
CJ7Sasquatch is offline
post #3 of 11 Old 02-16-2012, 02:57 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
If you have a swaybar, disconnect it/get some quick disconnects.
LT1CJ7 is offline
post #4 of 11 Old 02-16-2012, 03:32 PM Thread Starter
chevypowered
1981 CJ7
No i am not running and bump stops or a sway bar. I will defintally try disconnecting the front shocks. How do i know if it is flexed as far as it will go? When one of the rear tires lifts off the ground?
post #5 of 11 Old 02-16-2012, 04:03 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Other than that 4.5" Rough Country lift limiting travel, Then the only thing left is the shocks.
Did you take the additional length of the monster shackles into consideration when you ordered the length of your shocks ?
LT1CJ7 is offline
post #6 of 11 Old 02-16-2012, 04:03 PM
82JeepCJ7
1982 CJ7
Use a forklift and raise one of the front tires up until the back tire is about to lift off the ground. Measure one side to get your extended length, the other for your collapsed length. Just don't roll your Jeep in the parking lot.....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 11 Old 02-16-2012, 07:51 PM Thread Starter
chevypowered
1981 CJ7
No i did not even think of that. When i bought the jeep it just had the shackle lift, i put the suspension. Lift in and never changed out the shackles. Thanks
post #8 of 11 Old 02-16-2012, 07:54 PM Thread Starter
chevypowered
1981 CJ7
I dont have a forklift but i do have a lift so i could try throwing one of the armes under one side. Just put it under the u bolts should be good rite?
post #9 of 11 Old 02-17-2012, 07:02 AM
82JeepCJ7
1982 CJ7
Just as along as it doesn't slip off and totally bash in the under side of the Jeep. Maybe use a strap hooked to the axle and then to the arm...
Anyone have an RTI ramp in the area? Loading dock at a business?
post #10 of 11 Old 02-17-2012, 07:41 AM Thread Starter
chevypowered
1981 CJ7
Loading dock, thats a good idea if the lift idea dosent work out. thanks
post #11 of 11 Old 02-17-2012, 08:05 AM
CJ7Sasquatch
1979 CJ7
That's how I've always done it, loading docks are great and usually quite on the weekend
ECV 1864
