Not enough 12V Switched sources - Page 2 - JeepForum.com
post #16 of 20 Old 01-05-2014, 02:47 PM
WSS
WSS's Avatar
1972 CJ5
The nice thing about what you have for the dash lights is they won't flicker with tramp voltage. LED's work better with a clean input. I get some flicker through my ign. I can wiggle the key and see the dash lights flicker.
If you are a Purist, don't click here:
My CJ5 Build and fun stuff:
WSS is online now
post #17 of 20 Old 01-05-2014, 03:02 PM
CSP
Personally I would daisy chain the LEDs because there's so little amperage draw. That's just a personal preference. Your plan looks good.
CSP is offline
post #18 of 20 Old 01-05-2014, 04:31 PM
james04si
james04si's Avatar
1977 CJ5
Bluesea.com has some great fuse panels if you want to add some circuits to the wiring cleanly. I picked one up just never got around to removing the dash again.
james04si is offline
post #19 of 20 Old 01-06-2014, 05:07 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
AS CSP stated, LED's draw very little amperage. That being said, the stock light switch should be able to carry them with ease. This would eliminate a second relay and help clean up any extra wiring behind the dash.
jeepdaddy2000 is offline
post #20 of 20 Old 01-06-2014, 08:41 PM Thread Starter
Jester77
According to Autometer (Cory Villani - a tech over at Autometer), all the gauges at full load should be less than 1 amp total. Here's a video that demonstrates the load.
Although the video does not demonstrate the exact same gauges that I have (Phantom II), the current draw will be the same. I think a 4A fuse will be plenty.
I concur, the LEDs will be nothing.
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
