normal oil psi? - JeepForum.com
post #1 of 14 Old 03-24-2009, 09:37 AM Thread Starter
wetdog
normal oil psi?
What does a 258 s oil press settle down to after warm up ? I start out at 75 to 80 then it goes to about 25 is this okay ? is it a jeep thing ? Mark
wetdog is offline
post #2 of 14 Old 03-24-2009, 09:51 AM
DT5150
1983 CJ7
hey mark, welcome to the forum.
i used to have an image from the jeep service manual of normal oil pressure during start up and warmed up, but i can't seem to find. it. i don't recall the numbers off the top of my head, but yours sound just fine. the oil will get thinner as it heats up, thus the psi drop. are you getting these readings off the stock gauge? if you want true numbers, you can run a mechanical gauge in conjunction with your stock gauge.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #3 of 14 Old 03-24-2009, 10:17 AM
scottymac62
1977 CJ5
scottymac62 is offline
post #4 of 14 Old 03-24-2009, 02:02 PM Thread Starter
wetdog
Thanks , I have an auto meter mechanical guage the stock guage used to just kinda move around .
wetdog is offline
post #5 of 14 Old 03-24-2009, 02:59 PM
Bubba Ray
Your oil pressure sounds good to me. Mine max's at 25 psi.
Bubba Ray is offline
post #6 of 14 Old 03-24-2009, 03:03 PM
Mike Romain
Mine runs at 45-50 psi hot on the highway and 20 at idle. I have a mechanical gauge also.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline
post #7 of 14 Old 03-24-2009, 03:17 PM
Eaallred
Everything i've read from various automakers spec non-hydraulic lifter engines at 10 psi per 1000rpm fully warmed up with the recommended motor oil listed in the manual. My F-head idles fully warmed up at just a hair over 20 with 10w30.
I've never paid much attention to hydraulic lifter engine recommendations though. Your oil psi sounds in line with my other hydraulic lifter vehicles though from what I see on thier gauges (94 Silverado, 03 GMC van, 03 Honda Accord).
Eaallred is offline
post #8 of 14 Old 03-24-2009, 03:27 PM
fastang
1982 CJ7
As long as it comes up when you rev the engine or accelerate you should be fine.....
fastang is offline
post #9 of 14 Old 03-24-2009, 05:39 PM Thread Starter
wetdog
The pressure comes up instantly to at least 45 lbs/ psi This site rocks by the way thanks again.
wetdog is offline
post #10 of 14 Old 03-24-2009, 05:43 PM Thread Starter
wetdog
scottymac thanks for the info its printed and saved .
wetdog is offline
post #11 of 14 Old 03-24-2009, 06:44 PM
scottymac62
1977 CJ5
You're welcome but you need to thank JH....it's his web site.
post #12 of 14 Old 03-24-2009, 09:35 PM Thread Starter
wetdog
okay thanks jh it great info.
wetdog is offline
post #13 of 14 Old 03-25-2009, 03:24 AM
powermacj7
I was questioning my oil pressure as well. My gauge jumps around a bit. 20 at idle, and mostly 40 at high speeds.
powermacj7 is offline
post #14 of 14 Old 03-25-2009, 01:24 PM Thread Starter
wetdog
Iam glad I switched to mechanical guages the stockers are pretty bad at letting you know anything quickly.
wetdog is offline
Is this a NORMAL clutch?? imtheant Jeep CJ Forum 2 11-16-2006 12:51 PM
Is this normal? mideerhunter Jeep CJ Forum 9 12-27-2005 08:58 AM
Does this sound normal? vatalaro Jeep CJ Forum 4 11-16-2005 10:42 AM
Is this normal CGrugger Jeep CJ Forum 22 06-01-2005 09:02 PM
Is this normal? 73CJAZ Jeep CJ Forum 6 02-29-2004 10:09 PM
