Noob's Build Thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Noob's Build Thread
Free Shipping on Soft ShacklesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNew! JK/U skid plate system.
Unread 01-26-2014, 10:33 PM   #76
CJShayne
X2!
Originally Posted by chrisdj1992
just subscribing. I have to say you have done an incredible job. Considering what it looked like at first i'm speachless.
CJShayne is online now   Reply With Quote Quick reply to this message
Unread 01-30-2014, 09:47 PM   #77
76cjnoob
1976 CJ7
finished wiring my gauges, indicator lights and headlight and wiper switches. I also installed my pedals and steering column.
aluminum radiator is installed and master cylinder. however the radiator has to come back put so I can install my tranny cooler. I love doing things twice! I also have a new master cylinder coming from a CJ with front disks that should work with my disc brake swap.
still hoping to have it running in the next week or so. seems like I am constantly having to look for a bracket or needing to order another part. SBC swap is not as simple as most people think!
76cjnoob is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 06:50 PM   #78
76cjnoob
1976 CJ7
I ran into a little snag today. Bolted in my transfer case and got to the last bolt and popped the threads. had to pull it back put and put a helicoil in it. when I drilled out the hole for the helicoil I must not have been perfectly straight. I ended up studding that hole and got it to work. I also started bolting up the engine accessories.
Unread 02-07-2014, 08:03 PM   #79
76cjnoob
1976 CJ7
today I ran my tranny cooler lines and mounted my tranny cooler in front of the radiator. also installed most of my engine accessories.
Unread 02-09-2014, 08:16 PM   #80
76cjnoob
1976 CJ7
got it started today and broke the cam in. I was hoping to get that done in a few hours, but it took all day like everything!
http://static.photobucket.com/player...ps7d4a5a08.mp4
Unread 02-09-2014, 08:19 PM   #81
76cjnoob
1976 CJ7
haven't ever posted videos so let me know if these links don't work. here is another.
http://static.photobucket.com/player...ps0156b55b.mp4
Unread 02-09-2014, 09:22 PM   #82
lucdog
lucdog's Avatar
1980 CJ5
Links don't work on a iPhone. Nice work though!
. BG
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is online now   Reply With Quote Quick reply to this message
Unread 02-09-2014, 10:26 PM   #83
76cjnoob
1976 CJ7
. BG
do you know which link to paste off photobucket? I pasted the "direct" link. not sure if that is right
Unread 02-14-2014, 01:27 AM   #84
76cjnoob
1976 CJ7
spent most of my two days off prepping and painting a tailgate for a friend. I did manage to get a little work done. I welded in a receiver tube in the rear bumper that a fabbed up. also sprayed it with some duplicolor rattle can bedliner.
Unread 02-18-2014, 09:48 PM   #85
76cjnoob
1976 CJ7
I got some more work done today. Cleaned all the grease off my steering box and bracket. sprayed it with some black paint and got it mounted.
also found a combo of power steering pump brackets and pulley. painted them and got it mounted.
had to drill a new hole in my gas tank for the autometer sending unit. they make a fuel gauge that runs the same ohms as the stock CJ sending unit, but my kit came with a different one.
its starting to come together. getting all these little pieces and brackets painted is a pain and seems like it takes forever. still hoping to get it going before the weather warms up
Unread 02-27-2014, 07:25 PM   #86
76cjnoob
1976 CJ7
Still working at it. Finished up running my front brake lines and power steering lines. Also started wiring head lights and tail lights. Got a shipment of stuff from brown Santa today. too bad I have to work all weekend and will have to wait until Monday to get any more work down
Unread 03-04-2014, 08:21 PM   #87
76cjnoob
1976 CJ7
Got all my lights wired but had problems with my drivers side turn signals. Finally tracked it down to the turn signal switch in the steering column. Got that replaced and put a new steering wheel on today. Also spray lined my tube fenders
Unread 03-05-2014, 12:20 PM   #88
76cjnoob
1976 CJ7
I read on here a while back that AMC used duct tape as electrical tape. I thought they were full of it until I started going though my original harness to find some plugs. Seems like a major fire hazard to me!
Unread 03-09-2014, 09:13 PM   #89
76cjnoob
1976 CJ7
Got my fenders mounted. Brake lines and power steering lines bled. Filled both axles with fluid. Finished all my wiring. Just a couple more things and I will have it roadworthy. Need to finish bolting on my transfer case crossmember, put on hood and tailgate and put in driveshafts.
33x10.50 bfg at's on pro comp black steelies
Unread 03-09-2014, 09:24 PM   #90
76cjnoob
1976 CJ7
I also wired in an indicator light on my alternator. Just wired it into the exciter wire and it solved my charging problem.
