Noob's Build Thread - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Noob's Build Thread
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 05-18-2013, 03:28 PM   #46
76cjnoob
1976 CJ7
got started on my SBC swap. built my motor mounts and got them tacked in. Still have alot of trial and error going on. It was a pain but I finally got the Carb plate level both side to side and front to back. Going to mount an np205 next week and start building a tranny crossmember. If only I didn't have to work, I might get this done
76cjnoob is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 05:19 PM   #47
76cjnoob
1976 CJ7
I have owned my jeep for a year now!
got my th-350 and np205 mounted today. I welded some angle iron onto the stock Chevy cross member and bolted it through the frame rails. I ended up with a rear driveshaft length of 20 1/4 inches. Going to talk to the local drive shaft shop and probably have a Cv shaft made.
Unread 05-30-2013, 09:53 AM   #48
76cjnoob
1976 CJ7
didn't take any pictures, but spent about 6 hours stripping my hood yesterday. It was full of bondo, so it should be fun getting it straight.
Unread 06-05-2013, 03:50 PM   #49
76cjnoob
1976 CJ7
picked up my rebuilt and shortened/lengthened driveshafts today. $430 for both shafts and it took 2 days
Unread 06-17-2013, 10:34 PM   #50
76cjnoob
1976 CJ7
started working on my tube fenders today. I ordered the tubes pre bent from jeep tubes. I also got my shifter mounted last week.
Unread 06-18-2013, 09:54 PM   #51
76cjnoob
1976 CJ7
kept working on my tube fenders today. I got the drivers side done and the passenger side tacked together. still need to weld it solid and cut out the sheet metal. I am also still trying to decide what to do for inner fenders?
Unread 07-20-2013, 07:46 PM   #52
76cjnoob
1976 CJ7
I got my family bar fabbed up and also made wheel wells for my tube fenders out of 16 gauge.
Unread 07-20-2013, 07:52 PM   #53
BCrawford64
Pretty sweet, sorry if I missed it, but are you going to convert to coils or not.
BCrawford64 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 05:46 AM   #54
jhughes2013
1977 CJ7
Nice work! Love the flatty fenders and roll bar setup. The best part is you are making it all yourself.
'77 CJ7, LS1, NV4500/D300, Ford 8.8, 4" of lift, 33x12.50 BFG ATs...
jhughes2013 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 08:37 AM   #55
76cjnoob
1976 CJ7
nope I'm not planning on it right now, but who knows in the future.
Unread 07-21-2013, 08:38 AM   #56
76cjnoob
1976 CJ7
thanks, originally I didn't plan to do this much but I got it apart and have just started building stuff. I was hoping to have it on the road this summer, but its not looking good.
Unread 08-19-2013, 08:07 AM   #57
76cjnoob
1976 CJ7
I haven't worked on the jeep much lately. I did get the seatbelt mounting points tacked into the rollbar and the tub. I also started wire brushing the inside of the tub. Getting it ready for bedliner.
Unread 09-09-2013, 04:52 PM   #58
76cjnoob
1976 CJ7
I finally got back to work on the jeep today. wire brushed and sanded the inside of the tub. I have it ready to mask off and spray the liner on tomorrow
Unread 09-10-2013, 04:04 PM   #59
76cjnoob
1976 CJ7
Finally got the inside of my tub lined! I sprayed epoxy primer down then used seam sealer on all the seams and welds. I put down 2 coats on the floor and 1 on the sides. The bed liner looks funny in one of the pictures becuase it wasn't dry yet.
Unread 11-11-2013, 08:21 PM   #60
76cjnoob
1976 CJ7
sprayed the 2nd round of primer on the tub and hood today. Also started stripping the radiator support.
