Noob's Build Thread - Page 3 - JeepForum.com
post #31 of 97 Old 03-13-2013, 09:53 PM Thread Starter
76cjnoob
1976 CJ7
decided to flip my tub over and get the bottom lined so I can get it mounted on the frame for good. I scraped, wire brushed and sanded the bottom. started putting seam sealer on all the seams. I ran out of seam sealer about halfway thru. I am going to get it lined tomorrow with a u-pol raptor bedliner kit.
76cjnoob is offline
post #32 of 97 Old 03-14-2013, 09:23 PM Thread Starter
76cjnoob
1976 CJ7
Today I lined the bottom of my tub. I spent some time working on my rear bumper and getting my gas tank and skid plate to fit.
76cjnoob is offline
post #33 of 97 Old 03-14-2013, 11:53 PM
MoC
Solid looking work so far!
MoC is offline
post #34 of 97 Old 03-18-2013, 08:32 PM Thread Starter
76cjnoob
1976 CJ7
I have training this week for work so I won't be able to work on my CJ. I did get my tub sat back on the frame so my dad could roll it out of his way
76cjnoob is offline
post #35 of 97 Old 03-18-2013, 08:50 PM
RamblingCJ
That looks really good!
Did you prime it after scraping and sanding it? I see that you mentioned redoing the seams. I'm guessing you then primed it and then raptor lined it. I'm not familiar with that product, does it require any prep work other than a clean surface or does it need etching? It definitely looks nice!
RamblingCJ is offline
post #36 of 97 Old 03-18-2013, 09:03 PM Thread Starter
76cjnoob
1976 CJ7
I cleaned the grease and sanded/wire brushed everything the best I could. then I used paintable seam sealer on all the seams and used an epoxy primer over it. the epoxy is what I always spray over bare/rusty metal. after the primer I raptor lined it. I would definitely put some kind of primer down before the raptor liner.
76cjnoob is offline
post #37 of 97 Old 03-18-2013, 09:05 PM
DYontheForum
1981 CJ7
I see the c channel that has your capture nuts isn't stock. How does it work?
DYontheForum is offline
post #38 of 97 Old 03-18-2013, 09:08 PM
RamblingCJ
Thanks for clarifying that! Again, looks really nice!
post #39 of 97 Old 03-18-2013, 09:15 PM Thread Starter
76cjnoob
1976 CJ7
thanks. I'm really looking forward to getting it ready to paint in the next month or 2
76cjnoob is offline
post #40 of 97 Old 03-18-2013, 09:20 PM Thread Starter
76cjnoob
1976 CJ7
I'm not completely sure which part you're talking about? the PO had re done it once before me and I'm not sure what is original and what isn't.
76cjnoob is offline
post #41 of 97 Old 03-26-2013, 06:48 PM Thread Starter
76cjnoob
1976 CJ7
I have been pretty busy the last couple days. Yesterday I made body mount washers out of 5/8" flat washers and some scrap pipe. Sure beats paying $5.00 a piece for them. After I made all of them I got the tub bolted on and made sure my gas tank and bumper were going to fit. Today I cut out the holes for my oval tail lights and fuel neck. I spent this afternoon spreading bondo and sanding.
76cjnoob is offline
post #42 of 97 Old 04-22-2013, 08:32 PM Thread Starter
76cjnoob
1976 CJ7
still working on the body. I have made some good progress in the last week. I also realized that I needed the brace that runs from wheel well to the upper corner of the door frame. Since I had already started on the body work and didn't want to weld on the tub I decided to bolt it to the wheel well and glue it to the side of the tub. I fabbed up a couple braces and used 3M structural adhesive, that is used to glue body panels on. It doesn't pay to get ahead of yourself and have to go back!
76cjnoob is offline
post #43 of 97 Old 04-24-2013, 08:37 PM Thread Starter
76cjnoob
1976 CJ7
spent a few more hours doing body work yesterday. I am just about ready for primer, hoping to get the done Saturday!
76cjnoob is offline
post #44 of 97 Old 04-27-2013, 06:23 PM Thread Starter
76cjnoob
1976 CJ7
Finally got my body work done and primed it today! My body work wasn't as good as I thought, my dad had to smooth it out for me. I only put primer over the bondo. I will block sand it with 180 grit and re-prime the whole tub and block it again with 400 grit.
76cjnoob is offline
post #45 of 97 Old 05-13-2013, 08:20 PM Thread Starter
76cjnoob
1976 CJ7
I didn't get any work done last weekend on the jeep, but I went and picked some parts that were going to be scrapped. I pulled a th-350 and 2 np203 transfer cases. I also have another th-350 and a np208 to pick for my SBC swap. going to try and get some motor mounts built this week
76cjnoob is offline
