Noob Buying 79 CJ7 this week - Needs advice - JeepForum.com
post #1 of 17 Old 09-09-2007, 06:20 PM Thread Starter
mr burns
1979 CJ7
So, I've wanted a CJ7 since my friend in high school got one (that's like 15 years ago). Recently my wife and I decided to sell the mini van and she took my avalon. Now, I get to get something new! I decided it was time to live the dream. After stalking craigslist for several weeks I think I found a winner. Take a peek:
http://www.designsimple.net/463.jpg
So, my question is (me not being super mechanical) what do I need to look for when I check this thing out tomorrow? It has obviously had some work done. What questions should I ask? Any common trouble spots I should check?
I am really excited about the possibility of getting this jeep. I jsut don't want to rush in because it look nice.
Any help would be appreciated.
mr burns is offline
post #2 of 17 Old 09-09-2007, 06:24 PM Thread Starter
mr burns
1979 CJ7
Oh, and here are some of the things the guy listed about the Jeep... if they give you any additional insight for questions:
Newly rebuilt custom fit 350
New 4 Barrel Carburetor (Edelbrock)
New Water Pump and Fan
Chrome Side Pipes
Stainless accessories
Newer Soft Top and Doors
Newer Dashboard Cover
Newer Carpet
Newer Seat Covers
Newer Tires
Chrome Rims
Trailer Hitch
Heat Works
Fiberglass Body
Newer Paint (Midnight Blue)
Tilt Steering
Automatic Transmission
RENEGADE DECALS
Full Time 4x4
New Battery
Original Suspension
mr burns is offline
post #3 of 17 Old 09-09-2007, 06:44 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Hey, that jeep looks pretty sweet. Mind if I ask how much he's asking for it?
Also, just to pass the word along and help out a fellow JF member, someone was asking about specs for the RENEGADE decals. Maybe next time you go visit that jeep you can help him out?
http://www.jeepforum.com/forum/f27/lettering-dimensions-459136/
But anyhow good luck with it! Glad things are looking your way.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #4 of 17 Old 09-09-2007, 06:48 PM
mmerlina
mmerlina's Avatar
When I bought my CJ7 I was informed to pay close attention to the body mounts and make sure they were in decent condition. I was told that is a very common trouble spot.
Other than that man from the outside it looks pretty nice. Have him pop the hood and just make sure everything looks in order. Make sure it drives well (keep in mind it is a jeep
Check underneath it and make sure there's nothing super major to be concerned about.
There are a bunch of "common problems" with jeeps as I'm sure you will learn when you do buy one. But most of the solutions to those problems have been mainstreamed here and shouldn't be a huge deal getting it taken care of.
Good luck again,
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #5 of 17 Old 09-09-2007, 07:35 PM
79cj7reny
1979 CJ7
Common issues include frame rust/rot around body mounts, rot in rear section of frame( front is usually covered with oil so it won't rust ) Cracks in frame where steering box bolts to. Also cracks around body mounts and shock mounts. That jeep looks pretty good from here, but you'd be surprised at what you can hide under some undercoating and spray paint. Since the suspension is original you don't have to worry about improper mods. Now that you found us you can get steered in the right direction. Just remember though -J.E.E.P = Just Empty Every Pocket Think that's funny? Just wait! Good Luck!
79cj7reny is offline
post #6 of 17 Old 09-09-2007, 08:12 PM
SuB8HaVeN
That thing looks pretty clean! Just make sure and drive it (especially on the interstate) and see how it does and make sure it's something you're going to be able to do on a daily basis. If it's possible, pull up some of the carpet in the floorboards and check to see if there's any rust or if there has been any metal work done. One of the problem areas on the CJ tub is where the rollbar goes into the floor at each corner behind the front seats.
Also make sure to check underneath as mentioned above. A lot of times people like to just paint things and make them look pretty, but the underside is complete rust and falling apart. Check to see if he did a frame-off restoration on that thing; if he did chances are the frame and tub should be in excellent condition.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #7 of 17 Old 09-09-2007, 10:23 PM
T18A
1977 CJ5
T18A is offline
post #8 of 17 Old 09-10-2007, 05:12 AM Thread Starter
mr burns
1979 CJ7
The guy did mention that the only problem he knew of was some rust on the frame. He said something like he's taken it off and sanded and applied some clear coat (or something like that)... How much rust is too much? Also, forgive my ignorance, again, I'm not very mechanical, but where specifically is the "body mount" so I can be sure to inspect how much rust is there.
Looking at it today at noon. Will let you know how it goes.
Thanks for all the help everyone. Looking forward to joining the crew.
mr burns is offline
post #9 of 17 Old 09-10-2007, 05:29 AM
supraman1990
supraman1990's Avatar
1980 CJ5
Body mounts are the points on the frame that the body bolts to. Self explanitory once you look under the Jeep. My general rule, is if the rust is thru the frame, it's probably too much. Just think of the metal skills you have or are willing to pay for. If you think it's too much rust for that, then it's too much rust.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #10 of 17 Old 09-10-2007, 01:20 PM Thread Starter
mr burns
1979 CJ7
Thanks everyone. Just got back from the test drive and it drives like it looks! Amazing. Some rust, but not bad. Exhaust sounds very mean. Lots of power. Very excited. Plan on picking it up this weekend (guy is out of town rest of week).
Only things that surprised me were how difficult braking was. Seller said that was normal and you get used to it. Also, the sway in the steering was interesting. I had read some of the forums earlier about that issue, so I wasn't too surprised.
Thanks again.
mr burns is offline
post #11 of 17 Old 09-10-2007, 01:47 PM
TexasCJ7
How much was he asking?
83 CJ-8
86 CJ-7
TexasCJ7 is offline
post #12 of 17 Old 09-10-2007, 02:38 PM
SuB8HaVeN
Where was the rust at? You may want to double-check that. A lot of times it may just look like surface rust but it is actually rusted through.
If it doesn't have power brakes, then it's completely normal to have to really use your leg to get it to stop. That's how my 86 is but I've just gotten used to it. Once you drive it around for a while you'll be able to stop on a dime without thinking twice about it.
post #13 of 17 Old 09-10-2007, 03:48 PM Thread Starter
mr burns
1979 CJ7
$4,000 was the price we settled on.
As for rust, there wasn't any one spot that had it... it was just had general rust underneath. It didn't appear that the body mounts had any major rust issues. I went with supraman's advice that if it looked like too much, then it's too much. It was there, but I didn't feel like it was extreme for the age of the jeep. I could be wrong... but with the lower sale price I have a little leeway if I need to address any issues out the gate. Once I pick it up I'll post some detailed pics and everyone can tell me what I need to do.
Also, the jeep passed VA state inspection (http://www.vsp.state.va.us/Safety.sh...ectionProgram)... which gave me a little more peace about the deal.
mr burns is offline
post #14 of 17 Old 09-10-2007, 05:02 PM
muddmonky
its a fiberglass body how con u even call that a cj.
o ya if u take it offroad youll probably crack it like by buddy did his.
muddmonky is offline
post #15 of 17 Old 09-10-2007, 06:07 PM
SuB8HaVeN
Man I am such a tard. There I was telling you to check for rust on the floorboards...
For $4000, that sounds like a great deal by the picture. And especially if he's got a 350 V8 swapped in there. At least you won't have to worry about the fiberglass rusting. And working with fiberglass blemishes/dents/cracks is much easier to deal with than on steel IMO...
CJ noob Major Electrical Problem? also Tune up advice sought... skurtis Jeep CJ Forum 4 07-07-2008 07:46 PM
buying a cj need advice willyb8 Jeep CJ Forum 8 07-16-2007 05:42 PM
CJ noob, considering selling my TJ for CJ....advice needed 240M3SRT Jeep CJ Forum 18 01-20-2007 06:02 PM
I'm a noob and I need advice on EFI boosteddsm Jeep CJ Forum 1 06-10-2004 12:29 PM
advice in buying a cj IWannaCJ Jeep CJ Forum 1 08-14-2002 09:21 AM
