Good evening Jeep experts. I bought a 79 CJ 7 last week, 6 cyl, auto, Quadratrac. When I got it home and started going through it more I discovered that the light on in the gauge cluster is actually the light for emergency drive, not the brake warning light that I thought it was at first.
I did some reading and looking on here and learned how Quadratrac works, found the glove box and selector switch in a box of parts, the hoses to the switch and transfer case are gone, no big deal, I can fix that.
I got under the Jeep with a vacuum pump and tried the actuator, it works both ways, so now I have it in normal drive and am getting a snapping noise that I didn't notice before in the rear diff when turning sharply or under hard acceleration.
I jacked the rear up and in park rotated one wheel and watched the other, it turned in the opposite direction, ah, open diff says I. So then I tried a hard takeoff or two on dirt and grass both and cannot get any wheel spin just pulls hard with the snapping and a bit of a shudder.
What kind of mess have I got into? Is it a limited slip diff? Sorry, I don't know for sure which axle it is, does anyone have an id chart?
Sorry for the long post, just wanted to provide as much info as I could.
One of three things:
Either the LS in the T case is juttering or the chain is lose and ratcheting. I tend to discount the chain since it didn't do it with the E drive engaged. I suggest you drain the t case and refill it with either the recomended fluid or a mix of 90WT and friction additive.
Or you have a stripped hub on one of the two piece rear axles. Running the t case in E drive eased the strain on the hub, keeping it from spinning.
Mark the nut and the hub on both sides.
Power the Jeep till you hear the noise.
Check to see if the marks are still aligned.
If all else fails, drip the diff lid and inspect the diff. You may have a trac lok that has gone bad.
The hub has tapered splines inside that are cut and formed by the tapered splines on the shaft as it is mounted. There is a "woodruff" key also nestled on the shaft and hub.
If it was a Richmond Lockright locker it would click going into a turn but on jackstands it would turn both wheels in same direction. One way to find out is remove the diff cover and look. Diff gasket is not expensive.
The AMC 20 for a Q-trac is pretty easy to identify. They also have the offset pumpkin to the passenger's side. It should have (possibly only gears they came with) 3.54 gearing.
Here's a set I picked up last week for mine.
Here's what the stock two piece axles will look like. Under the dust cover, there is a large nut that holds the hub on.
I would be surprised if it was a spun hub. With the full time 4x4 splitting power to both front and rear axles, I doubt if it would create the torque to do it. Possible, but doubtful.
A slipping Q-trac chain would feel like major thumping right under your feet. Enough for you to feel in your soles under hard acceleration.
Seeing as you just bought it, it would be a good idea to open both diffs. Check the ratios, and change the oil.
Also drain and change the Q-trac oil in the t-case. You never know what the PO put in it, and the wrong oil will ruin it. Mine got trashed from the PO running ATF in it. :cheers2:
Okay, after a bit more driving I tend to think the noise is actually in the transfer case as has been suggested. I haven't had a chance to check anything physically as I have spent the last few days dealing with metal fragments in my eye, yes I was wearing safety glasses.
I'm trying to find a source for the proper transfer case fluid, jeepdaddy said a mix of 90w and friction additive will work, does any one know the mix ratio?
Hello folks, I'm back! I finally had some time to work on the Jeep, drained the t-case last night, let it drain overnight and this morning.
Did some other tinkering then refilled the t-case with 30 wt non detergent and friction additive/modifier as was suggested. Went for a drive, tried several tight turns and hard accelerations and yes, the noise is gone!
Thanks to all who replied with suggestions and info.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
