noise from clutch/tranny - JeepForum.com
post #1 of 2 Old 01-13-2010, 05:17 PM Thread Starter
wizim
77 cj5 with 232 manual 3 speed. when i just rest my foot on the clutch pedal it makes a whining type noise. is that the throwout bearing? can it be lubed? im sure being completely under water several times may have something to do with it.
99 corvette coupe h/c/i/ and a little nitrous ;) SOLD 77 cj5 4inch skyjacker 33's..SOLD
97 TJ IN THE PROCESS OF MODDING NOW.
04 f-350 psd crew cab 4x4. arp studs,gaskets,edge,mbrp 4inch straight pipe,20's on 35's
08 pontiac G8 GT lowered, longtubes,tune, 20's
wizim is offline
post #2 of 2 Old 01-13-2010, 05:26 PM
thantos858
1974 CJ5
It could be the bearing or the clutch itself. You should never rest your foot on the clutch as it will engage it slightly and cause quicker wear. Best option is to check the clutch and inspect it for improper wear and or damage. If your going through water a lot it could be debris from the water like mud, sand, sticks, etc. Also check your fluid you will probably need to change it.
thantos858 is offline
Clutch Noise TEXASROCKWELL Jeep CJ Forum 4 01-29-2009 08:08 AM
Clutch Noise cainebean Jeep CJ Forum 2 11-04-2008 08:50 AM
Problem: Tranny? or Clutch? or none of the above? deesgirl Jeep CJ Forum 5 01-18-2008 01:45 PM
Is it the Clutch or Tranny? jeepsarecool Jeep CJ Forum 19 07-09-2006 06:16 PM
Clutch noise ? 357 Jam Jeep CJ Forum 2 02-16-2005 08:42 PM
