No Voltage Regulator, how to add one? - JeepForum.com
post #1 of 14 Old 05-19-2013, 11:13 AM Thread Starter
ivansdad
1977 CJ7
Ok, so i bought a 1977 Jeep CJ7, with a 1985 Ford 5.0 or 302 V8 installed. The thing i've noticed while during a total re-wire is there is no Voltage Regulator anywhere on the vehicle. replacing the alternator today and the alternator clearly states, external voltage regulator needed, My question is how can i install one correctly....thanks
ivansdad is offline
post #2 of 14 Old 05-19-2013, 11:17 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would just use the same stuff found on a Ford 5.0. Find out the year and model it came out of.
John Strenk is offline
post #3 of 14 Old 05-19-2013, 11:27 AM
Dngrs1
1979 CJ7
Screw it to the fender.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #4 of 14 Old 05-19-2013, 12:26 PM Thread Starter
ivansdad
1977 CJ7
Would anybody know the wiring diagram needed to install? thanks
ivansdad is offline
post #5 of 14 Old 05-19-2013, 04:51 PM
wonfastws6
In the process of doing the same thing this is the guide Diagram I used.
wonfastws6 is offline
post #6 of 14 Old 05-19-2013, 04:52 PM
zillla
1930 VJ
Are you sure the Alternator doesn't self regulate?
Pull my finger
zillla is offline
post #7 of 14 Old 05-19-2013, 08:46 PM Thread Starter
ivansdad
1977 CJ7
new alternator had a sticker, external voltage regulator needed....
ivansdad is offline
post #8 of 14 Old 05-28-2013, 04:40 PM
zillla
1930 VJ
If it were me and once it was, I'd find a self regulating alternator and install that. Makes life a lot simpler
Pull my finger
zillla is offline
post #9 of 14 Old 05-28-2013, 11:44 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Same here... the 77 was originally set up with an internal regulated alternator, so I'd do that.
Rick
Cutlass327 is offline
post #10 of 14 Old 05-29-2013, 04:56 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Too easy. I love it when others do all the work
You may need to get a loom
jeepdaddy2000 is online now
post #11 of 14 Old 05-29-2013, 04:58 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
x3
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #12 of 14 Old 05-29-2013, 07:40 PM
jeepdaddy2000
1971 CJ5
I'm just curious why everybody wants to spend the money, time, and energy swapping in a Delco SI when there is a stock alternator already mounted. All it needs is a voltage regulator and a couple of wires. Heck the loom and the regulator should be an easy find at any u pick for next to nothing.
post #13 of 14 Old 05-30-2013, 02:57 AM
John Strenk
1976 CJ5
By the way, what alternator is on it ?
got a picture?
I think AMC V8 engines used an alternator with an External regulator.
but need to know which alternator we are talking about.
post #14 of 14 Old 05-30-2013, 08:38 AM
wonfastws6
What's probably happened is when the previous owner installed the new motor he most likely upgraded to a internally regulated alternator because they are Easier to wire. Then when the current owner order a new Alternator he probably just order a alternator for a 85 ford motor, Which I am sure is still a Externally regulated alternator. More info Required to help you get this problem solved.
