-   -   No Voltage Regulator, how to add one? (http://www.jeepforum.com/forum/f8/no-voltage-regulator-how-add-one-1525403/)
ivansdad 05-19-2013 11:13 AM
Ok, so i bought a 1977 Jeep CJ7, with a 1985 Ford 5.0 or 302 V8 installed. The thing i've noticed while during a total re-wire is there is no Voltage Regulator anywhere on the vehicle. replacing the alternator today and the alternator clearly states, external voltage regulator needed, My question is how can i install one correctly....thanks
John Strenk 05-19-2013 11:17 AM
603 Attachment(s)
I would just use the same stuff found on a Ford 5.0. Find out the year and model it came out of.
Dngrs1 05-19-2013 11:27 AM
Screw it to the fender.:D
ivansdad 05-19-2013 12:26 PM
Would anybody know the wiring diagram needed to install? thanks
wonfastws6 05-19-2013 04:51 PM
1 Attachment(s)
In the process of doing the same thing this is the guide Diagram I used.
zillla 05-19-2013 04:52 PM
Are you sure the Alternator doesn't self regulate?
ivansdad 05-19-2013 08:46 PM
new alternator had a sticker, external voltage regulator needed....
zillla 05-28-2013 04:40 PM
If it were me and once it was, I'd find a self regulating alternator and install that. Makes life a lot simpler
Cutlass327 05-28-2013 11:44 PM
Same here... the 77 was originally set up with an internal regulated alternator, so I'd do that.
jeepdaddy2000 05-29-2013 04:56 AM
Too easy. I love it when others do all the work:)
You may need to get a loom
RobsCrawlin7 05-29-2013 04:58 AM
x3
jeepdaddy2000 05-29-2013 07:40 PM
I'm just curious why everybody wants to spend the money, time, and energy swapping in a Delco SI when there is a stock alternator already mounted. All it needs is a voltage regulator and a couple of wires. Heck the loom and the regulator should be an easy find at any u pick for next to nothing.
John Strenk 05-30-2013 02:57 AM
603 Attachment(s)
By the way, what alternator is on it ?
got a picture?
I think AMC V8 engines used an alternator with an External regulator.
but need to know which alternator we are talking about.
wonfastws6 05-30-2013 08:38 AM
What's probably happened is when the previous owner installed the new motor he most likely upgraded to a internally regulated alternator because they are Easier to wire. Then when the current owner order a new Alternator he probably just order a alternator for a 85 ford motor, Which I am sure is still a Externally regulated alternator. More info Required to help you get this problem solved.
The time now is 01:55 PM.
