No spark, tired of buying parts - JeepForum.com
post #1 of 28 Old 10-24-2013, 04:57 PM Thread Starter
Misterzingle
I have an 86 cj7. It has a weber carb, and a new motor(258). I have replaced the distributor, the distributor button, the ignition coil, and the ignition module.
A week and a half ago I got in my jeep and might not have let it warm up ad long as I should have. She made it around a mile before she shut off going down the road. Once she stopped, she would only turn over. I have tested for spark and have gotten nothing.
I started doing the nutter bypass, but stopped after splicing the wires because I started to reAd that it was for the original Carter carb. Thoughts on if this would work?
Also, since I have started fixing her, or throwing my money down the drain, I've noticed my radio won't turn on. That was until I was messing with my fuses and tested my lights. I realized that the rAdio now only works when the headlight dimmer is on.
The fuel pump is working. Anything else that will help with a diagnosis, please let me know.
I appreciate all the help.
Misterzingle is offline
post #2 of 28 Old 10-24-2013, 05:30 PM Thread Starter
Misterzingle
Add a new ignition switch to that list
post #3 of 28 Old 10-24-2013, 05:33 PM
seabass1858
1983 CJ7
sounds like you got a short and you lost power to your ign control module (icm). first try testing for power going into the icm with the ign key on. http://www.jeep-cj.com/forums/f2/ign...l-issues-8109/, http://www.jeepforum.com/forum/f8/86...-spark-936569/ (post 8) heres a good dianostic advice
seabass1858 is offline
post #4 of 28 Old 10-24-2013, 06:32 PM
86cj74.2L
86cj74.2L's Avatar
Also check your grounds.
There should be a fat wire going to the engine block and a smaller one coming out of the battery clamp and going to the firewall within 6 inches of the negative terminal.
86cj74.2L is offline
post #5 of 28 Old 10-24-2013, 06:38 PM
ronppger
Sounds like a classic loss of ground problem. Mine died at a red light and I threw new parts at it and finally found the ground on engine block fro battery appeared to be tight, I removed and cleaned and scratched it up and tightened it to finally fix the problem.
ronppger is offline
post #6 of 28 Old 10-24-2013, 07:26 PM Thread Starter
Misterzingle
I did the test and got to step 8 where I was told the problem was indeed a ground, or at least that's where it's leading me. You mentioned some wires to check, you wouldn't have a better description or perhaps some pictures?
I'm going to keep working on it tomorrow.
post #7 of 28 Old 10-24-2013, 08:21 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by Misterzingle
I did the test and got to step 8 where I was told the problem was indeed a ground, or at least that's where it's leading me. You mentioned some wires to check, you wouldn't have a better description or perhaps some pictures? I'm going to keep working on it tomorrow.
The negative terminal of your battery should have two wires coming from it. One goes to the engine block and one gets attached to the firewall within a few inches of the battery negative terminal.
post #8 of 28 Old 10-25-2013, 03:39 AM Thread Starter
Misterzingle
There is the big wire and one open ended wire coming off of the negative battery terminal.
post #9 of 28 Old 10-25-2013, 06:17 AM
seabass1858
1983 CJ7
should go to firewall i believe
post #10 of 28 Old 10-25-2013, 06:47 AM
shadoow
it's important that not only the ground wires are there but they have good contact including the connection to the battery itself. Undo the ground connections at the battery, engine, elsewhere, etc. and make sure the wire terminals are clean, the connection points are clean then re-attach and make sure they are nice and tight. It's hard to tell if a connection is good just by looking at it so this is something you can do that won't cost you any $$
shadoow is offline
post #11 of 28 Old 10-25-2013, 11:43 AM Thread Starter
Misterzingle
When I was following the diagnostics test, it said that the negative on the coil wasn't grounded. Is there away to test that? I am thinking that a wire from the negative terminal of the battery to the negative on the coil will work?
post #12 of 28 Old 10-25-2013, 12:35 PM
86cj74.2L
86cj74.2L's Avatar
Here
post #13 of 28 Old 10-25-2013, 02:05 PM Thread Starter
Misterzingle
I have this wire that doesn't seem to have a connection
post #14 of 28 Old 10-25-2013, 02:12 PM Thread Starter
Misterzingle
Does the ignition module need to be mounted for the ground?
post #15 of 28 Old 10-25-2013, 02:59 PM
86cj74.2L
86cj74.2L's Avatar
that black wire with the yellow butt splice goes to the screw above the wire harness doing nothing in your picture. It's the exact same screw my body ground is attached too.
