No Spark Help - JeepForum.com
post #1 of 6 Old 01-16-2010, 06:50 PM Thread Starter
Woolys_CJ7
1976 CJ7
No Spark Help
I just finished rebuilding the top end of the 304 and everything is back together and hooked up as before when it was running. Engine turns over fine but we have no spark, checked at the number 1 cylinder and then from the coil to the distributer, no spark at either location.
I then followed the Chilton manual as best as I understood the trouble shooting procedure. What I found at the coil with the ohm meter was battery voltage from the positive terminal of the coil to ground, which is what the manual says is correct. Then I tested the negative side, have battery voltage, supposed to have 5 to 8 volts, further testing on coil made me question the coil and I purchase a new one. I still have battery voltage on the negative terminal, and no spark from the coil, check by turning engine over with ignition on and holding coil wire inch from a ground.
Looking for ideas and testing procedural help.
Thanks in Advance,
Wooly
Woolys_CJ7 is offline
post #2 of 6 Old 01-16-2010, 10:04 PM
TBailey
1983 CJ7
you my want to check your ignition module,I think most auto parts stores can test them for you
TBailey is offline
post #3 of 6 Old 01-16-2010, 10:36 PM
VACJ7
VACJ7's Avatar
Does your '76 use the Prestolite ignition? Jeephammer has some general testing procedures here and more specific info for the Prestolite: http://www.jeepforum.com/forum/f8/i-...0/#post7068393
VACJ7 is offline
post #4 of 6 Old 01-17-2010, 08:02 AM Thread Starter
Woolys_CJ7
1976 CJ7
Thank you the link to Jeephammers write up was exactly what I was looking for!
post #5 of 6 Old 01-17-2010, 04:09 PM Thread Starter
Woolys_CJ7
1976 CJ7
Result, it was the factory plug from the module into the harness no longer making a good connection. A little electrical contact cleaner followed up with dialectic grease and problem solved. Now to fix the exhaust leak.
Thanks
post #6 of 6 Old 01-17-2010, 09:22 PM
jfwireless
1976 CJ7
Well if you still have that original Presolite distributor and ignition, time to change that out.
Jim
jfwireless is offline
No spark from distributor to spark plugs poolshark909 Jeep CJ Forum 14 08-06-2013 05:36 PM
67 CJ6 w/V6 - no spark cghsatx Jeep CJ Forum 6 09-05-2009 11:19 PM
no spark! trueprimitive Jeep CJ Forum 7 08-26-2009 01:52 PM
304 has no spark? 1974cj5renagade Jeep CJ Forum 0 01-04-2009 01:45 PM
No Spark to the spark plugs Dandude80cj7 Jeep CJ Forum 6 09-11-2005 10:02 PM
