no spark!!! - JeepForum.com
post #1 of 4 Old 10-25-2003, 08:08 PM Thread Starter
NJCJ7
NJCJ7's Avatar
no spark!!!
all ignition parts are brand new... dist cap/rotor, plugs, coil, wires, ig. control module. ABSOLUTELY NO SPARK though... wtf? Here is a weird symptom, help diagnose if you would: when everything's connected the coil is hot to the touch even if just sitting there, not trying to start or having tried to start it for hours. Does that indicate a short or bad ground?
1985 CJ7 MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20
NJCJ7 is offline
post #2 of 4 Old 10-25-2003, 11:53 PM
awachwhiteboy
1975 CJ5
I'm by no means really knowledgeable of ignition systems, but it sounds like you said a ground. The coil may be getting a continuous feed of positive. Something is definently wired wrong. Get a hold of a wiring diagram and recheck everything you have, especially check the + side of the coil whatever i hooked there is wrong. Good luck with it.
Sacramento Jeepers Group #1
awachwhiteboy is offline
post #3 of 4 Old 10-26-2003, 04:43 PM
jadams68
jadams68's Avatar
Take the 2 connectors on the posts of the ignition module and reverse them...
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #4 of 4 Old 10-26-2003, 04:51 PM Thread Starter
NJCJ7
NJCJ7's Avatar
well, i'll be damned... after 2 days of fighting to get the thing started... it was the firing order! I double and triple checked it, but I was checking it to the wrong firing order! I rearranged the plug wires THE RIGHT WAY and she fired right up... when will i learn to suspect the simple things first???
NJCJ7 is offline
No spark from distributor to spark plugs poolshark909 Jeep CJ Forum 14 08-06-2013 05:36 PM
67 CJ6 w/V6 - no spark cghsatx Jeep CJ Forum 6 09-05-2009 11:19 PM
no spark! trueprimitive Jeep CJ Forum 7 08-26-2009 01:52 PM
304 has no spark? 1974cj5renagade Jeep CJ Forum 0 01-04-2009 01:45 PM
No Spark to the spark plugs Dandude80cj7 Jeep CJ Forum 6 09-11-2005 10:02 PM
