no spark! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > no spark!
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 05-14-2007, 07:41 PM   #1
spamman450
no spark!
Hi. My 85 cj7 was stalling while idleing. I thought it might be distributor related, so i popped the top off of my distributor to see if it was dirty. It looked good so i installed it and tried to start the jeep. It wouldnt even pop. i took a plug out and found i had no spark. I attached a plug to the coil. No spark there either. So now my jeep wont run and im sol. I found a leaky vacume line that was probably the original problem but broke something in the process! ugh.
spamman450 is offline   Reply With Quote
Unread 05-14-2007, 07:52 PM   #2
kavephish
1981 CJ5
If you have a stock ignition coil, you can test it this way:
Ignition Coil Test
Disconnect the ignition coil output wire at the distributor cap.
Connect a spark plug to the end of the ignition coil output wire which you just disconnected.
Connect a ground wire to the threaded portion of the spark plug.
Disconnect the ignition coil ground wire from the negative terminal on the coil (Green Wire).
Connect one end of a ground wire to the ignition coil negative terminal.
Turn the ignition switch to the ON position.
Tap the other end of the ignition coil ground wire jumper on an good grounding point (for example the battery negative terminal) and look for sparks at the spark plug that correspond to the frequency of your tapping of the ground wire.
If you have a good spark at the spark plug, the ignition coil is good.
If you don't get a good spark, check for approximately 12 VDC from the coil positive terminal (black wire) to ground with the ignition switch in the ON position. You should also get approximately 12 VDC from the coil negative terminal (Green wire) to ground
above courtesy of http://www.clarks-garage.com/shop-manual/ign-04.htm
Otherwise I'd suspect your ignition module if you've got one.
kavephish is offline   Reply With Quote
Unread 05-14-2007, 08:00 PM   #3
Mr.Crowley
1980 CJ7
x2.........
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Unread 05-15-2007, 11:29 AM   #4
bigjoe
1977 CJ7
Otherwise I'd suspect your ignition module if you've got one.[/QUOTE]
3x's on this as well. I had same issue with my Jeep. Turned out that I had a bad module and bad ignition wiring at the dizzy. Goodluck.
bigjoe is offline   Reply With Quote
Unread 05-15-2007, 01:20 PM   #5
spamman450
where is the ignition module? would it be a bad idea to convert this jeep to points to eliminate wiring issues?
Unread 05-15-2007, 01:38 PM   #6
kavephish
1981 CJ5
Ignition module is the 4" x 4" box under the radiator overflow bottle. I would stay away from going to a points system. The Ignition modules are cheap if you're in the states, and it's always goiod to have a spare. They can go at any time for no apparent reason and without warning.
