no power coming out of the solenoid with the switch in the "start" or "on" positions - JeepForum.com
post #1 of 6 Old 07-13-2010, 01:25 PM Thread Starter
SPless
Just joined up over here, and am trying to get an '80 CJ7 with a 4.2 running. I have a new solenoid, and have power going into the solenoid. I don't have power coming out of the solenoid with the switch in the "start" or "on" positions...I'm currently trying to track down the hot wire from the ignition and make sure the switch is actually hooked up. I realize the starter is probably locked up, but if I can just get power to the starter I would be happy.
SPless is offline
post #2 of 6 Old 07-13-2010, 01:31 PM
jeffyjensen
1980 CJ5
you can jump the solenoid to power the started.
Tips on doing a Battery draw test check this out it might help.
jeffyjensen is offline
post #3 of 6 Old 07-13-2010, 01:34 PM Thread Starter
SPless
I tried that with the old solenoid, by switching the switch on and connecting the terminals with a wire. When I got nothing I put a test light on the power wire going to the starter, and got nothing
SPless is offline
post #4 of 6 Old 07-13-2010, 01:44 PM
jeffyjensen
1980 CJ5
asuming you have a good ground, jumping from the bat side to the starter side should power the starter no matter what. other than that i got nothing.
good luck and welcome to the forum.
post #5 of 6 Old 07-13-2010, 01:52 PM Thread Starter
SPless
Thanks man....I guess I'm about to go check my wiring again. Excited to be here, and hoping I actually get the thing as I've already put ~6 hours of labor into it..
SPless is offline
post #6 of 6 Old 07-13-2010, 04:41 PM Thread Starter
SPless
I got it running guys...to be a 1980, and not cranked in a year all I had to do was to pour some gas in the carb and fire her up. She ran strong, and the 4wd bucked HARD...may need a power steering pump soon though. Ended up being what I was suspecting all day but couldn't find. The hot wire from the switch wasn't plugged into the solenoid.
SPless is offline
Help Please! Is Starter Solenoid Switch Bad? DirtEater Jeep CJ Forum 6 03-06-2010 09:32 PM
What is your Solenoid Switch wired to? SparkyCJ7 Jeep CJ Forum 10 08-26-2009 06:55 AM
Key will not start motor...Solenoid??? Jagernme Jeep CJ Forum 3 03-09-2009 03:42 AM
Solenoid also known as starter switch? TetanusCJ7 Jeep CJ Forum 3 01-25-2009 05:13 PM
Trans switch and solenoid questions Skrappi69 Jeep CJ Forum 0 09-17-2005 03:35 AM
