No high RPM power - Page 2 - JeepForum.com
post #16 of 20 Old 05-21-2013, 07:53 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Kevin,
I've read there are two distinct difference between the pre and post computer Motorcraft dizzys.
1. The pre-computer head has 13 and 18* advance slots. The computer version has 7 and 8* slots, roughly.
2. The computer version has a smaller range of vac advance that comes in slightly sooner.
I've had decent success with the NAPA re-man'd Motorcraft dizzys. If you decide get one, ask for a 1979 Jeep CJ distributer, and confirm that it has the correct 13-18* head. You can see the advance slot labels thru a little peep hole in the top plate.
Matt
Matt1981CJ7 is offline
post #17 of 20 Old 05-21-2013, 08:30 AM Thread Starter
CJKevin1978
Thanks Matt,
In that case my distributor is already pre-computer. Saves me some trouble but I would hoping that this was going to be the solution.
I just ordered a tach for under the hood. Once it arrives, I will plot the advance curve and see what is next. Luckily, the Jeep is completely usable as is, so there is no rush. If the advance is late, like I think it is, then I will make either a spring change or a weight change. As stated, it does advance, but I am not sure that it revs high enough on the road to start advancing.
CJKevin1978 is offline
post #18 of 20 Old 05-24-2013, 05:19 PM Thread Starter
CJKevin1978
My tiny-tach showed up today and it confirmed what I thought. I see no move in the centrifugal advance until ~2100 and I don't seen any real movement until almost 2400.
Springs too strong? It seemed smooth once it started moving and also when I turned the trigger manually, so I don't think its an issue of friction.
Will be away from the Jeep until next sat so any more adjustments will have to wait 'til then.
post #19 of 20 Old 06-09-2013, 09:12 PM Thread Starter
CJKevin1978
Been too busy to make any changes or do any more testing. But I have driven with it with the OEM tach and the new tach side by side. What I have found it that the power doesn't drop at an RPM as low as I thought. The OEM tach reads 500 RPM high at low revs and ~500 RPM low at high revs. So the engine doesn't fall flat at 3K like I thought but at 3500 which seems to be a little more like what I should expect.
I will still seek more centrifugal advance at some point.
post #20 of 20 Old 06-09-2013, 09:21 PM
GlennLever
GlennLever's Avatar
This may help;
Tune up on a 285 / Weber Carburetor / Distributor / Timing / Advance / Discussion
http://www.jeepforum.com/forum/f8/tu...ssion-1527457/
The guys helping you know what they are talking about.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
