No high gears - Dana 300 - Page 2 - JeepForum.com
post #16 of 21 Old 02-04-2012, 10:48 AM Thread Starter
jephwoyo
1983 CJ5
Thanks guys for all your help thus far. I'm waiting for a buddy to help me out, but a quick update I forgot to mention earlier.
When I put the transfer case in 4H, sometimes I have to release the clutch pedal a little bit and I can feel it go in. One time I heard the gears clunk in and I had to roll it a little bit to get it. That being said (and the fact my 4WD light comes on) tells me that I am going far enough back with the shifter and engaging the high gears.
Also, when I put it in 4H and crawl under... The plate that holds the rails is unseated from its slide, and both rails are still connected. The boot and everything else is off. I will drop the skid plate again later today to try and get a better look at it.
Again guys, thanks for all of the help/ideas. It's in the 70's here all week and I wanna get it out of the garage!
Jeff
jephwoyo is offline
post #17 of 21 Old 02-04-2012, 03:11 PM
foggybottombob
The 4WD light is driven from a switch on the rail for the front axle. The rail for the rear axle has no effect on this light.
foggybottombob is offline
post #18 of 21 Old 02-04-2012, 04:51 PM
Fingergrindr
You have the shift rod connection bracket installed wrong...If you need a pic let me know
Fingergrindr is offline
post #19 of 21 Old 02-05-2012, 01:55 AM Thread Starter
jephwoyo
1983 CJ5
A picture could be very helpful! Thanks!
jephwoyo is offline
post #20 of 21 Old 02-05-2012, 05:32 AM
mrgimble
2015 JK Wrangler
In 4 HI it will look like this. The plate nub will be out of the slide slot some.
mrgimble is offline
post #21 of 21 Old 02-05-2012, 10:01 AM Thread Starter
jephwoyo
1983 CJ5
Yep. That's exactly what it looks like. When you change from 2H to 4H it slides the guide out to the drivers side.
Still not working... May need to pull it again!
jephwoyo is offline
