No Heat, Blower doesn't work need wiring help - JeepForum.com
post #1 of 9 Old 10-16-2013, 09:14 AM Thread Starter
myridge
1979 CJ7
Well its all back together and I have found a few little odds and ends that don't work. The heater is one of them. The PO swapped in an aftermarket switch and when I rebuilt the jeep I went with a factory 3 speed switch. The PO removed the terminals from the factory plug and I am not 100% sure where they go back into the factory plug. I found a diagram using a search but my colors don't seem to match the diagram. I have TAN, TAN Stripe, Brown, Brown Stripe
Is there a way to test the blower motor? Could I put 12 volts to the terminal on the firewall or would that damage the blower? I just want to rule out a bad motor. If its bad I will do a blazer upgrade.
Also the red fiberboard on the resistor going to the duct-work is broken but the resistor looks OK. Would that cause a problem?
Attached is the diagram I found and an old before picture of the old aftermarket switch
myridge is offline
post #2 of 9 Old 10-16-2013, 09:16 AM
MoneypitCJ5
1977 CJ5
Yes, you can test the motor by hooking it up to 12V and ground. Doing this is the same as running the motor on the "High" setting.
I'd start by doing that anyway.
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #3 of 9 Old 10-16-2013, 09:22 AM
MoneypitCJ5
1977 CJ5
Those other wires just connect the various switch positions to the various resistance wires in the blower resistor. Even if they are hooked up in the wrong order, the motor will still work but the speeds will be wrong.
post #4 of 9 Old 10-16-2013, 10:49 AM Thread Starter
myridge
1979 CJ7
Thanks, All I get is a humm when I turn the switch to High which tells me the blower motor is bad.
I'll try and put 12 volts directly to the motor to rule out a bad resistor and if it really won't spin I guess I'll pull it back out and do the Blazer upgrade
If it is the resistor where can I get one? I don't see any listed online except for the YJ which actually looks very similar.
myridge is offline
post #5 of 9 Old 10-16-2013, 10:56 AM
MoneypitCJ5
1977 CJ5
I don't think the CJ's came from the factory with a resistor, although I could be wrong. I think mine is just an on-off thing.
Any resistor should work, provided it is meant for a three speed switch. The YJ should be just fine.
post #6 of 9 Old 10-16-2013, 11:28 AM
LeePrather
1978 CJ5
Originally Posted by myridge
Well its all back together and I have found a few little odds and ends that don't work. The heater is one of them. The PO swapped in an aftermarket switch and when I rebuilt the jeep I went with a factory 3 speed switch. The PO removed the terminals from the factory plug and I am not 100% sure where they go back into the factory plug. I found a diagram using a search but my colors don't seem to match the diagram. I have TAN, TAN Stripe, Brown, Brown Stripe Is there a way to test the blower motor? Could I put 12 volts to the terminal on the firewall or would that damage the blower? I just want to rule out a bad motor. If its bad I will do a blazer upgrade. Also the red fiberboard on the resistor going to the duct-work is broken but the resistor looks OK. Would that cause a problem? Attached is the diagram I found and an old before picture of the old aftermarket switch
I just finished putting my heater back in and upgrading to the blazer blower. The tan wire runs to the position under the blower motor. The tan and tan/white combine on the right plug on resistor, the brown/white plugs the bottom and the brown plugs in left. Your heater box grounds when secured to the firewall so if you test it outside of the vehicle you shouldn't get the motor turning.
LeePrather is offline
post #7 of 9 Old 10-17-2013, 09:41 AM
John Strenk
John Strenk's Avatar
1976 CJ5
It could be a mouse nest keeping it from turning also....
John Strenk is offline
post #8 of 9 Old 10-17-2013, 09:56 AM
texasdave
texasdave's Avatar
1980 CJ7
Or a screw driver, flashlight, ammunition I've found all that and more in the heater box.
texasdave is offline
post #9 of 9 Old 10-17-2013, 11:24 AM
arkiemurph
Go ahead and do the Blazer motor. They're cheap and man what a difference. Not only do you get a good heater, but you get defrost that actually works!
M
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
