-   -   No fuel to fuel pump on stock 1946 CJ2A (http://www.jeepforum.com/forum/f8/no-fuel-fuel-pump-stock-1946-cj2a-1354458/)
csmith28269 04-09-2012 12:32 PM
I have a "new to me" 1946 CJ2A more or less original. It was not running when I recieved it but engine turns over OK and all fluids are in decent shape, it was supposedly running in the past 6 months. It will crank and fire for a few seconds on starter fluid sprayed directly into the carb. It is not getting fuel to the fuel pump. I have replaced the fuel pump with a brand new original replacement and run a new, rubber fuel line from a gas can directly to the fuel pump intake to eliminate any issues with clogged fuel line, gas tank, etc. but still not getting any fuel into the fuel pump bowl.
Does anyone have any ideas on what else to check before moving to a more drastic tear down?
Thanks all for any assistance you can provide!
Jon In Tucson 04-09-2012 01:17 PM
Is the new fuel pump actually pumping fuel? Break loose the fuel line at the carb and make certain it is pumping fuel up to the carb. Have a helper turn the engine over while you hold the fuel line in a clean metal container. Inside of 30 seconds or less the fuel pump should move almost a 2 cups of fuel into your can. If the pump passes that test, then look at the carb for a blockage, plugged passage, or varnish in the bowl. If you move the accelerator linkage you should see a stream of fuel shooting in the throat of the carb. If not, then possible places to look are: a stuck needle valve or bowel float assembly, accelerator pump diaphragm dried up and not working.
Bottom line... If the fuel pump works and the fuel filter is good, then the next place to look is the carb.
God bless.
Jon In Tucson
csmith28269 04-09-2012 02:00 PM
That's the problem, the fuel pump is not pumping anything through. There is no fuel in the fuel pump while / after cranking so nothing is getting to the carb. It's a brand new fuel pump and I'm running a new, rubber fuel line directly from a gas can so I know there's no obstruction of fuel before the pump.
Balvar24 04-09-2012 02:23 PM
Is the cam engaging the fuel pump lever? Does the fuel line go to the BOTTOM of the fuel can?
Moncheche 04-09-2012 02:30 PM
Hmmm, have you tried any priming? Get a little fuel into to pump from the carb side, then crank to see if it will then draw fuel. Just a thought.
pman 04-09-2012 02:31 PM
4 Attachment(s)
This is what I'm thinking; either that or you happened to get another bad pump?
csmith28269 04-09-2012 02:52 PM
I'm confident on the line in the fuel can, not so on whether the cam is engaging the fuel pump arm. That's one of the first things I thought of, but don't know how to check and confirm that it's moving the fuel pump arm. Does anyone know of a way to test that?
Thanks for the help.
csmith28269 04-09-2012 02:53 PM
I'll try priming it this evening, I have not tried that yet.
Balvar24 04-09-2012 02:56 PM
When you put the fuel pump on, you should feel the pump lever come in contact with the cam and give some resistance to completely mating it to the engine.
You can probaly feel the cam lobe and tell if it is worn or not. It will be dished. More dish = more wear.
I prophesy a new cam or electric fuel pump in your future.
csmith28269 04-09-2012 03:10 PM
Thanks, I'll check the cam lobe for wear. I guess a new cam or electric fuel pump isn't the worst that can happen. Again, thanks all for the help!
skizriz 04-09-2012 04:05 PM
Smear a coat of grease on the pump arm where it makes contact. See if the grease gets smeared off or not.
WillysRookieTx 09-29-2014 06:42 PM
I'm having the exact same problem- no fuel in the glass bulb or the filter. Fuel pump is fairly new. Does it just need to be primed? How do I do that?
OrangeCJ-5 09-29-2014 07:49 PM
I did that by filling the carb bowl, starting the engine and letting it run until it died. It took a couple times for the pump to start pulling fuel out of the tank and remain running.
The time now is 07:52 AM.
