No breaking power with all new components... HELP! - JeepForum.com
post #1 of 40 Old 01-30-2014, 03:54 PM Thread Starter
DGRobles
No braking power with all new components... HELP!
Please help!... I never thought to say this but I am about to quit... I can't solve my problems with brakes and taking the jeep outside the city with this conditions make me evaluate other alternatives (TJ)...
So here is the background... I upgraded to vacuum booster brakes but I can't get enough braking power to block the tires or do emergency braking...
I changed my proportioning valve, I have the 8" diameter booster, brand new master cylinder from Chevy Astro, new brake lines, new valve check on the booster, hose for vacuum is new and is not collapsing... new pads...
Man, everything is new now and I still have problems...
I tested the booster to see is that was the problem but no, no leaks at all.
Braking power (assisted) came occasionally and I do not know under what conditions, with it I can block and make an emergency stop really easy but then suddenly I have no assistance...
So... pressing the pedal at half brakes good, but when I floor it it behaves like mechanical...
Any suggestion?... What could it be?
DG
Diego Robles / XE1XZQ
DGRobles is offline
post #2 of 40 Old 01-30-2014, 04:02 PM
LumpyGrits
Where did you run the vacuum line for the booster to?
Can you in fact 'pull' vacuum on the booster?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is online now
post #3 of 40 Old 01-30-2014, 04:18 PM Thread Starter
DGRobles
I run it directly from the manifold... and yes I can pull vacuum on the booster...
here is the setup,
DGRobles is offline
post #4 of 40 Old 01-30-2014, 04:44 PM
LumpyGrits
With the altitude of Mexico City. Have you taken a vacuum gauge reading to see how many 'inches' of vacuum you have?
Does your engine run a stock profile camshaft?
LG
post #5 of 40 Old 01-30-2014, 04:46 PM
Spieg8
1984 CJ8
Are you using stock brakes (disc/drum)? Curious why you went with that MC? Not being familiar with the specs... what are the piston cylinder dimensions (volume)? Also, what proportioning valve did you use to replace the stock unit?
Spieg8 is offline
post #6 of 40 Old 01-30-2014, 04:56 PM Thread Starter
DGRobles
The engine is completely stock 258, no modifications on camshafts... also brakes are stock disc/drum setup.
Originally I had the MC1321H kit
but had problems with the MC, so I checked the specs on the ports and bore diameter (1") and the chevy astro has exactly the same specs but 50% lightweight.
the proportioning valve was bought at Morris, and was marked as the direct OEM replacement for the one I had installed...
DGRobles is offline
post #7 of 40 Old 01-30-2014, 05:13 PM
Knucklehead
1973 CJ5
Had a similar problem when I swapped in a new master cylinder and booster - found that the problem to be inadequate bleeding of the master cylinder. Had to work hard at getting all the air out of the MC bore but once done, and bled the entire sytem again, the brakes worked great.
WJ Build: http://www.pirate4x4.com/forum/jeep-cherokee/2171458-wj-build-sd-axles.html
Knucklehead is offline
post #8 of 40 Old 01-30-2014, 05:20 PM
LumpyGrits
I vote to 100% rebleed the system.
Can you do a pressure bleed?
LG
post #9 of 40 Old 01-30-2014, 05:41 PM Thread Starter
DGRobles
I can do pressure bleed as I do not have the hardware, however I can try to get it here to do it...
Is this the more recommendable procedure?... pressure bleed?
DGRobles is offline
post #10 of 40 Old 01-30-2014, 07:30 PM
LumpyGrits
At this stage, I feel it's your best option.
Just make sure you have a hose coming off the bleed-nipple into a bottle with some brake fluid already in it.
Do one wheel at a time, and do the whole procedure twice.
Best of luck and post up results.
Fingers crossed
LG
post #11 of 40 Old 01-30-2014, 08:24 PM Thread Starter
DGRobles
Thank you LG! Keep you informed!
This is the toy in problems...
DGRobles is offline
post #12 of 40 Old 01-30-2014, 08:31 PM
LumpyGrits
Kool picture-Where was it taken?
LG
post #13 of 40 Old 01-30-2014, 08:53 PM Thread Starter
DGRobles
LG
Mexico City, outside the city, a place called Ajusco....
DGRobles is offline
post #14 of 40 Old 01-30-2014, 09:00 PM
LumpyGrits
IIRC, from when I lived in Mexico City as a kid. It's south of the city isn't it? One of the highest mountains in all of Mexico.
Beautiful country for sure.
LG
post #15 of 40 Old 01-30-2014, 09:22 PM Thread Starter
DGRobles
LG
That's right!...
DGRobles is offline
