No 3rd or 4th gear - JeepForum.com
post #1 of 5 Old 05-12-2011, 05:30 PM Thread Starter
tlannom
No 3rd or 4th gear
I lost 3rd and 4th gear today on my 86 CJ7. It has a G-Force T5 5 speed transmission. First, second, fifth and reverse all work fine. Any ideas what the problem is? I would love for someone to come on the forum and tell me there is a reset button.
'86 CJ7 Laredo, LS1 Corvette engine, AX15 transmission, Dana 300 4:1 twin-sticked, RE 4 1/2" lift, YJ cage, Bzerk front/ rear bumpers
tlannom is offline
post #2 of 5 Old 05-12-2011, 06:00 PM
Coiz
1979 CJ7
Well, they share the same synchronizer and shift fork so that would be a good place to start. If it was a slow grinding death, I would suspect the synchro. If it was working fine then made a noise and quit, I would suspect the shift fork.
Mike
Coiz is offline
post #3 of 5 Old 05-12-2011, 06:10 PM Thread Starter
tlannom
Everything was working fine, then it popped and went out. Is the shift fork difficult/ expensive to repair? Thanks for the help.
tlannom is offline
post #4 of 5 Old 05-12-2011, 06:17 PM
Coiz
1979 CJ7
I would pull the cover and see what you've got before you go ordering parts but a 3-4 shift fork should cost you around $20. There are 3 on eBay for $17.50 + $5 s&h.
Look at pages 3-4 and 3-7 in the T5 Rebuild Manual for the parts in question.
Better yet go to Morris4x4 and look at numbers 17 and 39. My guess is you will need the 3-4 shift fork number 39.
Mike
Coiz is offline
post #5 of 5 Old 06-08-2011, 09:17 PM Thread Starter
tlannom
Update: I finally got around to pulling the transmission out. Turns out I broke the main shaft right behind the 3rd and 4th gear syncros. Definitely not going back with a T5. Probably going with a NV4500 or SM465.
tlannom is offline
AMC 20 gear oil? Mugger Jeep CJ Forum 1 04-11-2011 12:58 AM
Gear Questions from a Gear Noob jeepsarecool Jeep CJ Forum 5 02-26-2010 07:56 AM
Gear Down CarlJay Jeep CJ Forum 6 07-18-2006 07:26 AM
What gear? Mud4U Jeep CJ Forum 5 09-18-2005 07:38 PM
Speedometer gear after gear change rcsutton Jeep CJ Forum 9 01-26-2005 02:32 PM
