Newbie, transfer case boot, NP205 in a CJ7 - JeepForum.com
post #1 of 9 Old 01-12-2013, 09:30 PM Thread Starter
auskier
1983 CJ7
First time poster, 1983 CJ7.
PO installed a 350 chevy, SM465, and NP205 drivetrain. I am in the process of a semi restoration and need suggestions on what to use for a transfer case shifter boot. Currently I have an open slotted hole.
Thanks,
Brian H.
auskier is offline
post #2 of 9 Old 01-27-2013, 03:20 PM
haro504
1979 CJ7
Have you looked at a Dana 20 transfer case boot? How does your drivetrain fit/work? I have all the same components, and I've been going back and forth about the np205 and getting an adapter for my Dana 20 due to the length. But seeing how people are using the np205 I might give it a shot and save 500.00
haro504 is offline
post #3 of 9 Old 01-30-2013, 10:21 PM Thread Starter
auskier
1983 CJ7
I really like the setup, it was installed when I bought the jeep. Only thing is the final drive ratio isn't 1:1, so mileage is only about 11.5. I can take pics of my front and rear axles if you want.
Brian H.
auskier is offline
post #4 of 9 Old 01-31-2013, 05:55 AM
haro504
1979 CJ7
Oh you don't need to take any pictures, thanks though. I was more concerned on the length of the drive train. But as I've been looking into it. It seems it would be fine.
haro504 is offline
post #5 of 9 Old 02-21-2013, 04:44 PM
CherryCj7
1979 CJ7
Brian H.
I was doing research on my SM465/NP205 swap and have a couple questions for you. First, I thought the final drive on the SM465 was 1:1? Also, I would love any pictures of the drive line that you have such as the T-case position, skid plate, transmission/t-case shifter locations... Anything would be appreciated if you could!! Thanks for any help that you can offer!
CherryCj7 is offline
post #6 of 9 Old 02-21-2013, 08:22 PM
Thbugman
1978 CJ7
What are you using as a boot for the SM465??
Thbugman is offline
post #7 of 9 Old 03-01-2013, 08:58 PM Thread Starter
auskier
1983 CJ7
I'm planning on using a dana 300 boot for the transfer case. PO used a Mr gasket universal boot, that works pretty well for the trans. THe dana boot will overlap a little but should be OK. I just ordered a new Mr Gasket boot off Ebay, $15 delivered. I'll snap a few pics of the driveline/shifter positions. I'm gonna start a build thread soon, and will be sure to post stuff there too.
Brian
auskier is offline
post #8 of 9 Old 03-02-2013, 11:56 AM
kw89425
Brian H.
Why do you think its not 1:1? Final drive is direct drive which is 1:1 in high gear in any transmission unless it has over drive.
86 cj7 496 powered 465/205 ton axles 38.5 boggers
kw89425 is offline
post #9 of 9 Old 03-02-2013, 09:43 PM Thread Starter
auskier
1983 CJ7
Thanks for the correction. I guess I read somewhere that it was 1.08:1
Brian
auskier is offline
