Newbie qustion - JeepForum.com
post #1 of 8 Old 08-10-2005, 06:05 PM Thread Starter
jeepin_man
Newbie qustion
Besides the Cj7 being 10" longer, what are the main differences between a Cj7 and a Cj5?
jeepin_man is offline
post #2 of 8 Old 08-10-2005, 06:21 PM
dawgates
1980 CJ7
Doors. the CJ5 has an "S" shaped door where the CJ7 has a "U"
In later years the CJ7 changed to wide track axles, which carried on to the YJ and TJ.
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline
post #3 of 8 Old 08-10-2005, 06:23 PM
Military Jeeper
1979 CJ5
Dawgates pretty much summed it up. Doors and Axles and you already know the stretch issue.
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
post #4 of 8 Old 08-10-2005, 06:35 PM Thread Starter
jeepin_man
I heard there is a bit of a height diff. as far as the interior goes. I am 6'3 and judging by the pics of the 5's I might have an issue with them
post #5 of 8 Old 08-10-2005, 06:38 PM
Military Jeeper
1979 CJ5
CJ 7: http://www.jeeptech.com/models/cj-7.htm
CJ 5: http://www.jeeptech.com/models/cj-5.htm
post #6 of 8 Old 08-10-2005, 07:39 PM
Xrossed
Xrossed's Avatar
Im not sure.. But I dont think the CJ5 has a tailgate.... Or does it?
Xrossed is offline
post #7 of 8 Old 08-10-2005, 07:49 PM
Military Jeeper
1979 CJ5
Depends on the year......mine doesn't and it's a 1979.
post #8 of 8 Old 08-10-2005, 09:03 PM
plain76cj5
Until the early 70's, tailgates were standard on the CJ5. After that, 71 or 72 I think, it was optional.
As far as the height difference, it is more of a "steering wheel clearance" problem. The CJ5 seat will only go back so far. Someone 6'3" may have a little trouble getting in and out of a CJ5.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline
Dana 30 Qustion trashmaster2k Jeep CJ Forum 1 03-30-2009 10:49 PM
Wheels anr rims qustion Big John Jeep CJ Forum 3 09-08-2006 02:27 PM
Newbie CJ-7 standfas Jeep CJ Forum 2 05-24-2006 10:12 AM
Newbie & newbie question! mytjtoy Jeep CJ Forum 4 10-31-2005 10:10 PM
Newbie here.... xxxspank Jeep CJ Forum 4 09-08-2004 10:11 AM
