Newbie with a question - JeepForum.com
post #1 of 7 Old 10-22-2003, 08:25 AM Thread Starter
Tcat55371
Well, I just picked up a 76 CJ 7 with 304 and Quadratec. All in all in pretty good shape. I noticed a clicking noise in the rearend when turning and it seems to bind. I'm going to pull the cover and take a peek to see if there are pieces floating around. I was told there is a special additive to add from jeep when I put it back together. Is there anything else I should be looking for?
Thanks for the post and I've found some good info already off here so I'm sure someone can point me in the right direction.
Take care guys....
Tcat55371 is offline
post #2 of 7 Old 10-22-2003, 09:12 AM
jadams68
jadams68's Avatar
Take care guys....
Well is it locked in the rear? If so, that's probably where you're clicking is occuring because certain lockers purposely interfere with the turning aspects of the vehicle. The close wheel to the turn spins slower than the outer wheel and when locked, you can experience mild to heavy racheting.
Another thing...Open the diff and check for a broken tooth on the ring gear or pinion gear.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 7 Old 10-22-2003, 09:14 AM
wm69
your clutches in you tcase might have varnish coating that doesn't allow them to slip when you turn. If you can't find anything in the rear that looks suspect, check that next (info fromt my jeep owners bible, which I have currently misplaced or I would provide more info).
wm69 is offline
post #4 of 7 Old 10-22-2003, 09:30 AM Thread Starter
Tcat55371
Thanks guys
Just got the additive from Jeep. Will tear into it tonight and take a peek. I had a 76 years and years ago and it never made this noise that I remember so I must have a problem somewhere.
post #5 of 7 Old 10-22-2003, 11:11 AM
TrappG
TrappG's Avatar
Do you mean you have Quadratec or Quadratrac? If you meant Quadratrac, chances are that it's not the rear end at all. I had the slip/stick condition in my 78 304 with QT (characteristic of the QT transfer case) I simply replaced the QT fluid and all strange binding, and noises went away.
'78 CJ7 - 304 - Hooker Headers/Sidepipes
TH400/QuadraTrac, B&M shifter (sold spring '04)
'04 Sahara - I6, 5spd bone-stock...
TrappG is offline
post #6 of 7 Old 10-22-2003, 12:06 PM Thread Starter
Tcat55371
Should watch my spelling
It's Quadratrac but the binding and clicking (which is low and loud) is coming from the rear end and only when turning. Does not need to be a tight turn either, just turning. It sounds like something binding and breaking loose. I will find out tonight when I pull the cover I guess. Worse that can happen is I have to have it rebuilt and since it's out that gives more reason to do a spring over lift.
post #7 of 7 Old 10-23-2003, 05:34 AM Thread Starter
Tcat55371
Not sure but....
Pulled the cover and the lube was milky color. Must have had water in it and sat for awhile. I cleaned everything out with brake cleaner and shot a coat of oil in it. Going to put the cover back on tonight and put new oil and addititive in it.
Does anyone know if Mopar 4318060-AB Lube is the correct stuff? My book calls for Jeep #8991018. The guy at the parts counter didn't seem to know much about it for a Jeep dealer.
Newbie Oil Question jeepvosser Jeep CJ Forum 2 07-07-2006 10:12 AM
newbie question rwm Jeep CJ Forum 3 11-29-2005 12:24 PM
Newbie & newbie question! mytjtoy Jeep CJ Forum 4 10-31-2005 10:10 PM
newbie question punkaroo85 Jeep CJ Forum 1 11-05-2004 10:22 AM
Newbie here with a question Hy-Brid Jeep CJ Forum 2 12-13-2002 11:22 AM
