Newbie Clutch/Transmission Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Newbie Clutch/Transmission Issue
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 09-18-2014, 07:29 PM   #1
Sethro123
Hey all! Thanks ahead of time for your help.
I just bought this old Jeep yesterday (1985 CJ7 with the 2.5L 4 cylinder and 4-speed manual transmission) and tonight on my drive home from work it would no longer go into 1st or 2nd gears. It felt as if the stick wouldn't let you even find the gears.
I'm not sure if the clutch has gone out, slave cylinder, or if I have a dreaded transmission issue. The clutch pedal feels soft to me but, I haven't had this Jeep long enough to really establish a baseline for what is normal.
Any ideas on things to look for and estimates on the cost of repair?
Best,
Seth
Sethro123 is offline   Reply With Quote
Unread 09-19-2014, 12:32 AM   #2
BagusJeep
BagusJeep's Avatar
1981 CJ7
Turn the engine off and see if you can engage the gears.
If you can it is the clutch. If you can't it may be the selector lever.
If the clutch look for leaks in the system and then try bleeding it.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote
