New to Winch - Page 3 - JeepForum.com
post #31 of 74 Old 02-28-2013, 08:59 AM
Noplainsdrifter
1974 CJ5
Originally Posted by 00sarhara View Post
The moment you find out that your cheap chinese winch doesnt work is the moment you need it the most, what about when you need replacement parts? Saving money is always good but when you need to get off the trail or stuck a winch that will perform is priceless. The two major problems to cause a winch to fail is lack of use and abuse.
People need to understand that all things need maintainence, your Jeep, your car and your winch. You just don't jump in any rig and drive it and ecpect it to last forever.
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
post #32 of 74 Old 02-28-2013, 09:02 AM
WindKnot
1977 CJ7
The first thing I'd do is price out an off road recovery. They aint cheap and THEY'RE your comparison.
Figure out what kind of winch capacity you need. If you mud, you're going to need a heavier duty winch; MUCH heavier rated. Generally speaking, a safe sized winch is about 3 times your vehicle weight. Remember too that the winch rating is for the BOTTOM WRAP of your cable. Each wrap on the drum of your winch lessens its ability.
Don't count on being able to run your engine while winching. Vehicle angles, water, etc. can make running the engine impossible at worst, not desired at best.
Winching is more than owning a winch. It also means understanding basic concepts such as leverage. You also want to own a "recovery kit" with snatch blocks, slings, straps, etc. How many snatch blocks? I take four along with me, but some consider this overkill. They also don't believe you can pull yourself out backwards with enough snatch blocks.
I believe synthetic cable is nice, but not necessary. It certainly has its advantages such as being lighter and not storing energy so that if it snaps, it drops instead of flying through the air. I also think that it has disadvantages. It is more fragile and more suseptible to being damaged by rocks and logs. In my prior career, I did lot's of winch work working for a telecommunications company. All we ever used was steel cable except for pulling cable underground. We'd use a sandline there so that we didn't damage ductwork. Steel winch lines work just fine.
If you're buying a winch to look cool, buy what you want. If you're buying the winch to get yourself or your buddies out of a jam, save your money and buy the best you can. There are reasons why Ramsey and Warn are expensive, and they're good reasons like series wound so that they stay ccoler, higher ratings with heavier gearing, etc.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #33 of 74 Old 02-28-2013, 09:25 AM
lucdog
lucdog's Avatar
1980 CJ5
im only going to add this.
If your winching your friend up a incline like shown in the picture.Where a winch failure could cause injury or damage, what winch do you want. The $400 special, or the best one money could buy? Is it worth taking a chance?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #34 of 74 Old 02-28-2013, 11:14 AM
Renegade82
1982 CJ7
I had read somewhere, and I don't remember where but it was on the net (and your not allowed to put anything on the net that isn't true, right?), that there are only 2 winch companies out there, Warn and I believe it was Ramsey. And they sell them to other companies to be rebranded and those folks add the remaining parts. If you look at all the winches out there in this newly created economy market, the base winch is the same but with different paint, clutch knobs, and solenoid boxes. So are we argueing a mute point? We may never know. But I'm sure the top of the line quality still would remain with those 2 companies, as will the higher prices.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #35 of 74 Old 02-28-2013, 11:33 AM
Jack61
1981 CJ7
I would stick to a name brand like Warn, Superwinch, or Ramsey. I have never had to buy a new winch as I have been very lucky to find used ones at great deals. The warn 8000 on my Jeep cost me $250 on ebay shipped and was in perfect condition. The warn 8000 on my sons scout I traded parts and labor for and works great. The 9500 Superwinch on my truck, I was in the right place at the right time and it was given to me. I've burned the motor up on it once but it was easy to find a replacement and it didn't cost a fortune. The costco special 8000 lb winch on my car hauler was given to me for usage time and has worked perfect for over 6 years but at the same time I wouldn't put it on one of my vehicle's, that and if it breaks I don't imagine it would be easy to find parts for. I agree with Windknot that the synthetic rope is probably pretty nice but I play in area's like lucdog pictured and at $200 plus for synthetic I'll stick with steel cable.
It used to be, God bless America, it has become God help America
Jack61 is offline
post #36 of 74 Old 02-28-2013, 12:53 PM
Manhattan
1981 CJ8
Originally Posted by yahwhy View Post
Just get the Engo and put a warn sticker on it. Thats what I did, works for me...
Here's your next project:
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #37 of 74 Old 02-28-2013, 12:59 PM
82JeepCJ7
1982 CJ7
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #38 of 74 Old 02-28-2013, 01:08 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Too FUNNY, Manhattan.
(see below)....33 years old, been used a ton, never been re-built, and still operates and looks like new.
Who can say the same about their Mile Marker, Engo, or Harbor Freight winches?
Matt
Matt1981CJ7 is online now
post #39 of 74 Old 02-28-2013, 01:16 PM
Renegade82
1982 CJ7
Isn't that what Chrysler uses in their Toledo plant?
post #40 of 74 Old 02-28-2013, 02:10 PM
markso125
1982 CJ7
Originally Posted by stamp32 View Post
No it seems more like he got bitterly fired by Mile Marker
nope cant bring myself to do inferior work... Says the guy that builds airplanes and rockets.... But anyways I bought an old truck years ago when I was still a teenager and went out and bought everything the guy at Mr 4x4 told me too (they are out of buisness now) as shiny and as pretty as all the mile marker stuff was it just didnt hold up to wheeling in a half ton truck, wasted a good chunk of money on that chinese garbage.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
markso125 is offline
post #41 of 74 Old 02-28-2013, 02:23 PM
markso125
1982 CJ7
The premium brand names like warn are built in the US (so part of that premium pricetag goes to giving Americans paychecks)
I believe superwinch is built in brazil and the US (I know their hubs use to be all built in Brazil. They were built by a company called AVG)
But...most of the cheap ones like mile marker, engo, and harbor freight are built in china.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
post #42 of 74 Old 02-28-2013, 02:29 PM
yahwhy
1982 CJ7
Yeah, probably wouldn't take me 4 1/2 years to finish that.
Just go down to the local paint store and get the gayest blue the have.
yahwhy is offline
post #43 of 74 Old 02-28-2013, 03:23 PM
row684
Pssh my buddies buddy got me a free ride in a snowcat after he got his Wrangler stuck in UT last year and then my friend got his sisters Cherokee stuck trying to rescue him. $1600, a snowcat a wrecker,and 24 hours later he was finally out of the ditch a winch would have saved him from in the first place.
row684 is offline
post #44 of 74 Old 02-28-2013, 04:47 PM
74Maverick
People actually pay a service to have someone unstick their jeeps? I personally like to rope many vehicles together and all pull at once, when there is no winch or hi lift. You can pull out the titanic that way. Or just 2 retarded 1/2 ton stock chevys. We had 4 vehicles roped together that day, it was super sloppy on that trail. Right after a snow melt, only the front vehicle had 2 tires on dry dirt. We also crossed a river that way all roped together, almost as good as those camel trophy boys.
Anyway moral of the story. A tow truck? Really?
The Last Great American Hero... the demi-god... to which speed means freedom of the soul.
74Maverick is offline
post #45 of 74 Old 02-28-2013, 06:19 PM
WindKnot
1977 CJ7
Originally Posted by 74Maverick View Post
People actually pay a service to have someone unstick their jeeps?...
Yes, really. And they aint cheap. It's hard to lash Jeeps together when there's only one or two of you.
winch , winch accessories , winch bumper , winch install
