new wheel problem - JeepForum.com
post #1 of 10 Old 11-03-2011, 06:04 PM Thread Starter
David2012
new wheel problem
So i just bought new wheels for my 85 cj7. i like the aggresive look of a wide stance so i went for the 2.5in bs. when i put them on my jeep the brake assembly pin on the brake caliper rubs against the inside of the rim. what could cause this, and what might i be able to do to fix it. Please help, i dont even feel safe driving my jeep it makes such horid scraping noises.
Electrical gremlins will be the death of me... 85 cj7
David2012 is offline
post #2 of 10 Old 11-03-2011, 06:35 PM
CJ7ROB
Get wheel spacers to bring the wheels out just enought to clear, otherwise get some different wheels.
CJ7ROB is offline
post #3 of 10 Old 11-03-2011, 07:41 PM Thread Starter
David2012
any other recomendations because at the moment thats out of budget and with 2.5in bs i dont need them sticking out any further than they already do. got new wheels 3days ago... not getting new new wheels....
post #4 of 10 Old 11-03-2011, 07:45 PM
shull360CJ7
The unfortunate reality is that you have wheels that won't work without spacers, which in some states are not permitted and some would advise against using in general. That being said, I would list them on Craigslist and try to recoup 3/4 if your $ then buy wheels with a usable amount of backspace. I'm sure it's not what you want to hear but it's my 2 cents.
Brian
'98 Sport, 5 Speed. Green Emerald Metallic. Bestop soft top.
BDS 2" lift, AR steel wheels, 31"x10.5" Goodyears. Stock axles, stock 3.07 gears.
Immigrant from the CJ world...be patient...I can be taught
shull360CJ7 is online now
post #5 of 10 Old 11-03-2011, 08:34 PM
skizriz
1978 CJ7
Why would they rub with less backspacing than stock? That would set them out away from the caliper.
Is it thicker material that's making the center of the rim a smaller diameter?
Is it barely scraping?
Can the pin be CAREFULLY ground down a hair for clearance?
Got any pictures???????
skizriz is online now
post #6 of 10 Old 11-03-2011, 08:38 PM
notforsale
1977 CJ5
Dont abandon hope yet. And whatever you do DONT GET DISCOURAGED!!! Upload some pics if possible
notforsale is offline
post #7 of 10 Old 11-03-2011, 08:57 PM Thread Starter
David2012
its dark and i only have a camera via my phone. but yes it is so slightly scraping that its rediculous. i was thinking the gridning of the pin but didnt know if that was safe. my old wheel (eagle alloy) is shaped completely different than my new wheels (pro comp rock cralwer). the old ones were completely open on the inside and the new ones, i guess due to the backspace, are more filled in. that probably doesnt makes sense but i dont know how to rxplain it really. would scraping the pin just a hair or two be safe? would that be a reasonable fix?
http://www.4wheelparts.com/Wheels/52...PCW52-5885R2.5 cheapo wheels i know but thats them
post #8 of 10 Old 11-03-2011, 09:09 PM
lucdog
lucdog's Avatar
1980 CJ5
I would really like to see a picture, exactly at the rub point.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #9 of 10 Old 11-03-2011, 10:35 PM Thread Starter
David2012
Bill
okay so i took a picture.. it turned out well... but ive sent it to my email 400 times and it wont go thru. w.e... bedtime
post #10 of 10 Old 11-04-2011, 06:10 AM
lucdog
lucdog's Avatar
1980 CJ5
Sending you a PM.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
grinding noise , rims , rubbing noise , wheels
Four wheel drive problem? RedHotChiliDog Jeep CJ Forum 4 11-01-2010 09:09 AM
1978 cj7 problem going int 4 wheel drive extremecj7 Jeep CJ Forum 7 12-24-2008 10:14 PM
wheel balance problem wjr Jeep CJ Forum 9 02-04-2007 09:18 PM
fly wheel problem outdoordad@comc Jeep CJ Forum 2 12-30-2005 12:00 PM
Rear Wheel Bearing Problem... Swedish_K Jeep CJ Forum 6 06-21-2005 03:55 PM
