New Weber 32/36 DGEV stalls on turns... - JeepForum.com
post #1 of 9 Old 10-12-2013, 06:57 PM Thread Starter
CJ7-78
1978 CJ7
So I replaced my old card with a new Weber 32/36 DGEV and what a big diff in smoothing out my rough idle.. BUT The engine still stalls out when I idle around a turn. Runs fine if I am on the gas around a turn just at idle. I have a pressure regulator on it and have tried to set it from 2lb up to 4lb with no luck. Vacuum is good no leaks. Any ideas ???
CJ7-78 is offline
post #2 of 9 Old 10-13-2013, 04:22 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Float settings?
John Strenk is offline
post #3 of 9 Old 10-13-2013, 10:54 PM Thread Starter
CJ7-78
1978 CJ7
John, I have read a ton on this float setting. Some say not to mess with it as it involves bending things and other say to do it. I read this well informed thread on here but it did not go into detail on how to fix the float setting. The crazy thing is the old carb (5+ years old) was a 32/36 and it did the same thing as well.. Where can I look to get detailed info on setting the floats.
CJ7-78 is offline
post #4 of 9 Old 10-14-2013, 05:57 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
FYI, I never had to mess with the float level on either of my Webers.
The fact that your engine displays the same symptoms with both the old and new carbs makes me think it's something else.
What are you plugs reading?
Matt
Matt1981CJ7 is offline
post #5 of 9 Old 10-15-2013, 08:24 PM Thread Starter
CJ7-78
1978 CJ7
Matt,
The plugs were gaped at .45-.50. I just today bought Champion platinum plugs and the specks from Champion for the 258 call for .32.. So I put them at .32. still stalling out at idle clutch in around turns. runs great in gear around a tune!
CJ7-78 is offline
post #6 of 9 Old 10-15-2013, 08:31 PM
seabass1858
1983 CJ7
fuel pump not cutting the musterd? filter clogged? maybe the diphram in the fuel pump is shot
seabass1858 is offline
post #7 of 9 Old 10-16-2013, 08:03 PM Thread Starter
CJ7-78
1978 CJ7
Seabass,
I will look into that next.. thxs..
CJ7-78 is offline
post #8 of 9 Old 10-17-2013, 11:39 AM
scrapman
Do you have power brakes? If so, are you on the brakes when it dies? Could be a hole in the brake booster.
scrapman is offline
post #9 of 9 Old 10-17-2013, 11:51 AM
uptillnow
uptillnow's Avatar
I have found that the float height is the usual fix for this stalling on turns.
Try the height of 18mm from gasket to the top of the float.
The gasket is vertical, closing the needle valve, without the weight of the float on the dampening ball and spring, as shown in my picture.
Hope this helps.
UPTILLNOW
uptillnow is offline
