new transmission - JeepForum.com
post #1 of 6 Old 09-10-2012, 09:17 PM Thread Starter
ETJ85
new transmission
I have a 85 jeep cj7 with a 4 speed transmission but i dont know which one it is but i want to get a 5 speed transmission. I was thinking about getting the T5 but its lightduty so im not sure how it would do with the 33s. Is the a better 5 speed or should i just stay with the stock 4 speed i have?
ETJ85 is offline
post #2 of 6 Old 09-10-2012, 10:04 PM
only in a jeep cj
What hurts "light duty" transmissions is the load placed on them from the wrong axle gears OR in another way, the incorrect gears for the tires.
Example: T5 + 2.72 gears+33s=bad
T5 + 4.10 gears+33s=good
When regeraed correctly for larger tires, the load or extra leverage from the large tires is taken by the ring and pinion.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 6 Old 09-10-2012, 10:32 PM
my-jeep-earl
1971 CJ5
An NV3550 would be nice!
my-jeep-earl is offline
post #4 of 6 Old 09-10-2012, 10:42 PM
only in a jeep cj
I fully agree. Its the closest thing to the feel and ratios of the older T5s. Plus much stronger. I wish I could find them in my area..
Ed
1975 CJ-6 1983 CJ-8
post #5 of 6 Old 09-10-2012, 10:59 PM
BagusJeep
1981 CJ7
Novak transmissions have a good web site that is worth reading before taking the plunge.
The T5 is not worth spending big bucks on fitting, there are stronger alternatives out there. 5th gear is usually an overdrive gear but the depth of gearing from 1st to top is worth thinking about as this will determine how useful it will be and is also related to axle gearing.
If you have the T176 4 speed then it is worth retaining and exploring why you need a 5th gear overdrive. If you have a T4 it is not a great piece of kit.
they are reaily identifiable from under the vehicle.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 6 Old 09-11-2012, 07:51 AM Thread Starter
ETJ85
it looks like i do have the t176. The only reason i would want the 5 speed is for a better highway ride but wasnt sure if it would make that much of a difference on road and offroad. But since you said the T176 is worth keeping then i probably will.
ETJ85 is offline
T4 transmission re-do Ironhorse6 Jeep CJ Forum 7 11-01-2011 09:17 AM
transmission for amc 360 primezero Jeep CJ Forum 1 05-25-2010 08:45 AM
T-18 Transmission 79jeepguy Jeep CJ Forum 50 02-10-2010 11:26 AM
t-150 transmission newjeepowner Jeep CJ Forum 7 03-14-2009 04:35 PM
T-98 Transmission and 258 TreeKiller Jeep CJ Forum 2 03-11-2005 07:35 AM
