New steering box for CJ5 - JeepForum.com
post #1 of 20 Old 01-24-2010, 11:41 AM Thread Starter
torlak_t
i am thinking of replacing my old loose steering box on a 79 cj5 with a stronger one. i usully do mudding, not rock crawling etc. however, looking to get some heavy duty one as i run tractor tires on my jeep. which is the strongest steering box you would recommend for $500 - $700 price range.
torlak_t is offline
post #2 of 20 Old 01-24-2010, 02:08 PM
2dswithaCJ5
Sounds like you might need the hydraulic assist upgrade.
I can do anything, just give me instructions.
2dswithaCJ5 is offline
post #3 of 20 Old 01-24-2010, 02:27 PM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
Also, if you are that hard on your steering box, you might want to brace it if you haven't already. I know I have a rebuilt one and thought it was going out until I looked under the Jeep while someone turned the wheels and I watched it dance back and forth an inch or so. The CJ's aren't known for keeping accessories attached to the frame all that well.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #4 of 20 Old 01-24-2010, 02:43 PM Thread Starter
torlak_t
what do you mean by brace? can u explain that a lil bit pls..im noob to steering unfortunately
torlak_t is offline
post #5 of 20 Old 01-24-2010, 02:55 PM
JeepinYahoo
1977 CJ5
Well there are two types I can think of off hand, the best is the HD mount that is in the first link. I have the rod style brace that is in the second link and would prefer the HD mount but in 3 years I have not had any problems with mine. It keeps the steering box from wandering when you saw the wheel. If you wheel remotely hard and haven't braced it, it likely moves a bit and you don't even notice. Sure made driving on the highway a whole lot less scary once I installed mine and made the sloppy steering much better.
here are some links:
Amazon.com: MORE SB7686 Heavy Duty Steering Box Bracket and Hardware, No Paint for Jeep: Automotive
Amazon.com: Steering Box Brace - Warrior 1976-1986 Jeep CJ5, CJ7, CJ8 WAR897: Automotive
post #6 of 20 Old 01-24-2010, 03:02 PM Thread Starter
torlak_t
yeah i see the point now..mine was dancing just like yours and altough i had tigtened them it still has got some play in it..anyway, i ll def. get one of those but what about the steering box? which one should i go with?
torlak_t is offline
post #7 of 20 Old 01-24-2010, 03:07 PM
JeepinYahoo
1977 CJ5
Not sure, I just use a stock one. Works fine for 33" and under tires. Do you have power steering?
post #8 of 20 Old 01-24-2010, 03:13 PM Thread Starter
torlak_t
yes, i have power steering. can anyone explain me how to strength the whole steering for cjs pls? because, i believe thats the weakest part of my cj..
79 CJ5 with Tractor Tires and loads of other extras!
torlak_t is offline
post #9 of 20 Old 01-24-2010, 03:20 PM
2dswithaCJ5
If you're running "tractor tires" I would still not rely on the stock anything from a CJ steering system. Of course, in my mind, tractor tires are , I am thinking of something like this...
http://farm3.static.flickr.com/2015/...4d49f1a48c.jpg
What do you have?
post #10 of 20 Old 01-24-2010, 03:29 PM Thread Starter
torlak_t
no, thats waay too big for me, those are 33 inch equivalent.
torlak_t is offline
post #11 of 20 Old 01-24-2010, 03:45 PM
2dswithaCJ5
In that case, upgrade to an AGR style steering box and box, then check the tire rods... get new poly for them... and yeah.. .don't forget the steering box bracket!
post #12 of 20 Old 01-25-2010, 08:49 AM Thread Starter
torlak_t
is agr strong enough? also can you give me a link pls, by the way the stock one is 20 spline, will 15 spline make much of a diffrence, i mean is it better to have quick steering while offroading?
torlak_t is offline
post #13 of 20 Old 01-25-2010, 10:25 AM
2dswithaCJ5
I just picked up this from a forum member...
http://www.jeepforum.com/forum/f130/...r-pump-951304/
post #14 of 20 Old 01-25-2010, 12:54 PM Thread Starter
torlak_t
how does it perform compared to stock one? also, how long u been using that?
torlak_t is offline
post #15 of 20 Old 01-25-2010, 01:09 PM
2dswithaCJ5
I just picked it up. I am on the look out for a steering shaft and pump bracket. Will update in a couple months when it is installed. Sorry, I coudn't provide any immediate pro's and con's. Do a search on the forum under AGR, there might be other threads here on the subject.
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Coupler connecting steering gear to steering shaft is leaking? Natto123 Jeep CJ Forum 1 06-29-2008 12:52 PM
Trouble removing steering gear from steering shaft.... Natto123 Jeep CJ Forum 5 06-29-2008 10:56 AM
Size of the nut for steering column to hold steering wheel supraman1990 Jeep CJ Forum 4 02-07-2008 06:16 PM
