New Speedo Gear Does Not Fit - JeepForum.com
post #1 of 11 Old 01-08-2012, 07:39 PM Thread Starter
NoNative
I bought this new speedo gear from PATC transmissions for my 86 CJ-7. Here's the link to their website - http://www.transmissioncenter.net/sp...n_______va.htm
I'm running 33X10.5 KM2s regeared to 4.10s with a Dana 300. With that info the guy sold me this long shaft gear with 33 teeth. See the pics below.
The only problem is the technician who's done a ton of work to my CJ said it didn't fit. This guys really good so I assume he's on the money.
Where did I go wrong? I'll take all the help I can get.
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline
post #2 of 11 Old 01-08-2012, 08:08 PM
only in a jeep cj
The main difference I see is the gears I've seen have squared teeth where yours has rounded teeth that seem larger. Of course your guy did have it in the correct index? as there are 3 settings depending on size.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 11 Old 01-08-2012, 09:07 PM Thread Starter
NoNative
Tell me what you mean by "index" and "3 settings". Assume I know very little about speedo gears and you'll be giving me too much credit.
Thanks for your help!
NoNative is offline
post #4 of 11 Old 01-08-2012, 09:51 PM
VACJ7
VACJ7's Avatar
He means the housing that holds the speedo gear has an arrow on the side. The top part has three lines and are stamped with gear size range. Like 28-34, this is just an example. The next index might be something like 35-38. Again, I am making up these numbers. You have to align the correct index range with the arrow on the housing.
Here ya go.... picture is worth everything. There is a small notch for each range. Not the hold-down notches. http://www.jeepforum.com/forum/f8/no...2/#post6803542
Scroll down and you can see the arrow that Yellow85cj painted red.
'84 CJ-7 |
VACJ7 is offline
post #5 of 11 Old 01-08-2012, 10:34 PM
foggybottombob
That gear looks normal to me. I would bet your mechanic did not turn the holder to the right index like VACJ7 said. It is very easy to turn the gear holder to the right index. The holders usually have so much grease on them that you don't notice that it has gear range numbers all around it.
foggybottombob is offline
post #6 of 11 Old 01-09-2012, 05:26 AM
waterdowg
That were I got mine from. It was right on money, once I lined up the holder to the mark.
waterdowg is offline
post #7 of 11 Old 01-09-2012, 06:04 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My speedo gear stopped fitting when my a$$ got too big for it.
Sorry, I had to say it
Matt
Matt1981CJ7 is offline
post #8 of 11 Old 01-09-2012, 06:11 AM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by matt1881cj7
my speedo gear stopped fitting when my a$$ got too big for it.
Sorry, i had to say it :d
matt
please, no pictures.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #9 of 11 Old 01-09-2012, 07:31 AM
85LaredoCJ7
Any more info on this? I have 4.56 gears and 32" tires. How do I know what gear to order? Is it a do it yourself, or leave it for the tranny guy?
85LaredoCJ7 is offline
post #10 of 11 Old 01-09-2012, 07:39 AM
foggybottombob
You need to use a GPS and drive at about 50 to 60 mph true speed (on the GPS). Then note your speedo indicated speed against your true speed. The ratio of the two will tell you how much you need to increase or decrease the tooth count on the gear you have. Once you have two speed numbers and know what gear you have now, post it here on the forum and 40 people will tell you how to figure out what gear you need.
Assuming you have a Dana 300 Tcase. You can pull out the gear holder you have now and check your current gear in about 5 minutes.
post #11 of 11 Old 01-09-2012, 07:56 AM
waterdowg
Once you have the gear it is a do it yourself job. Have unscrew the speedocable nut, remove one bolt. Pop out the speedo gear holder. the gear should come out with it. The reverse the order. Its really easy...
Speedo gear CJhollic Jeep CJ Forum 3 08-19-2009 10:46 AM
Speedo gear wvcj7 Jeep CJ Forum 1 04-08-2008 08:47 PM
speedo gear badge1236 Jeep CJ Forum 2 02-17-2008 10:50 AM
Speedo Gear RenegadeKing81 Jeep CJ Forum 13 01-16-2008 08:22 AM
speedo gear atomicflatulenc Jeep CJ Forum 18 07-20-2007 01:49 PM
