New Speaker/head unit install in 86 CJ-7 - JeepForum.com
post #1 of 4 Old 09-19-2017, 04:48 PM Thread Starter
86renegade
Hey everyone, I purchased a new radio head unit thing, some marine speakers and a marine amplifier for my CJ. Upon installing everything and wiring it to what the diagrams for everything show to be correct I cannot for the life of me figure out why I can't get substantial sound to come from the speakers.
I've double checked my wiring for everything but I cant get it to work right. There is music that comes out but its very faint even will the amplifier and when I turn the output volume all the way up on both the head unit and the amplifier the music becomes more audible but its very distorted.
86renegade is offline
post #2 of 4 Old 09-20-2017, 09:38 PM
Spieg8
1984 CJ8
Are the speakers/amp/head all of the same Ohm rating (4 Ohm or 8 Ohm?). Most mobile units will be 4 Ohm but there are exceptions. A mismatch can behave much like you have described.
When I was younger, I thought I was Don Quixote... turns out I'm just another donkey-hootie.
Spieg8 is offline
post #3 of 4 Old 09-21-2017, 09:50 AM
JoonHoss
2011 JK Wrangler
Are you running everything thru the amp?
What type of RCA cords did you use? Did you use pre-amp outputs, Or did you use line level inputs
Do you have the gain on the amp up?
What make HU, speakers, and amp? What are the ratings?
2 Speakers only? Did you wire them front or rear? Do you have it faded?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #4 of 4 Old 09-21-2017, 10:25 PM
258
Make sure you have SOLID grounds. Has similar issue once and it was the ground connections.
258 is offline
