New shackles not straight? - JeepForum.com
post #1 of 17 Old 03-09-2013, 07:45 PM Thread Starter
10129
I just finished installing some new 4 inch shackles from Crabtree Tool. Excellent quality and easy to order. The wierd thing is now that they are installed the both seem to kick out to the sides. Is this normal or is something else bent? Opinions or suggestions?
1981 Jeep CJ7
258,T-5, D300, NT AMC-20 & Dana 30 (4.10)
Locked front and rear
10129 is offline
post #2 of 17 Old 03-09-2013, 08:50 PM
bajaviking
1976 CJ7
Looks like maybe you tightened the shackles too much or you need to cut the spacer in the middle down a little bit.
76 CJ7 6 cyl/t18/Dana 20
05 TJ HP30/8.8 with ARB's Rubicrawler Flatbelly Midarms/3" lift and 35s
bajaviking is offline
post #3 of 17 Old 03-09-2013, 08:51 PM
gojeepin
1983 CJ7
Did you change any of the other spring mounting points?
The shackles will point laterally outward at the spring if your mounting points from the frame to the axle to the shackle aren't inline with the frame.
As an example:
1) If your springs are mounted 27.5" apart at the frame (spring eye)
2) If your springs are 28" apart at the axle perch
3) The shackle's frame mount is 27.5" apart.
4) Your shackles will lean outward (the springs will be about 28.5" apart at the shackle)
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 17 Old 03-09-2013, 08:56 PM Thread Starter
10129
No, I just removed the stock shackles and put these on.
1981 Jeep CJ7
10129 is offline
post #5 of 17 Old 03-09-2013, 09:13 PM
zillla
1930 VJ
How about the stationary shackles?
It kinda looks to me like the hangers are not square.. or possible you have the wrong shackles. I'd remove the center bar and have a look see.
What year Jeep?
Pull my finger
zillla is offline
post #6 of 17 Old 03-09-2013, 09:37 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Rear shackles mounted on the front it looks like to me.
Also loosen U-bolts to get everything lined up and retighten perhaps?
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #7 of 17 Old 03-10-2013, 08:12 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
+1
Also snug everything up nice, while on jackstands and TQ to spec while it has its' own weight on it. I don't even know if it matters, but it looks like MAYBE some nuts are run down the bolt more than others, but that could be my bad eyesight. The nuns warned me about that!
Also check to see if the grease fittings are facing in the easiest direction to service. W/O looking at mine, or better yet ANYBODY elses,....I can't say yours are wrong.
Good luck, and let us know how you make out.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #8 of 17 Old 03-10-2013, 10:20 AM
zillla
1930 VJ
The next thing I would do is loosen up all the bolts and remove the center brace, then retorque and see what it looks like. . The center brace length being incorrect is the only thing that makes sense.. I have the same thing only made by M.O.R.E and mine look straight.
One m ore thing. Did you install the metal sleeves in all the bushings?
Pull my finger
zillla is offline
post #9 of 17 Old 03-10-2013, 01:46 PM
gosupes
No sleeves in these bushing, the bolt shank is 1/2" dia, larger than the stock setup.
I have the same shackles and found the center sleeve to be a bit too wide for the brand of bushings I was using (Daystar maybe?). I don't know if there are differences between brands or what the original shackle design was measured for, but for the time being, I left the sleeve out and just installed the center bolt. Did the same thing as everyone has mentioned and jacked it up, loosen u-bolts, snug the bushings, retorque u-bolts. Seems a little better, but I have not put a lot of miles on it since then. I need to beat on the suspension a bit and see where it sits after that.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #10 of 17 Old 03-10-2013, 05:48 PM
zillla
1930 VJ
I can see the problem in the pic below which I got from Crabtree's site. w/o the sleeve the bushings will collapse if tightened too far.. I am not impressed with this design..
Pull my finger
zillla is offline
post #11 of 17 Old 03-10-2013, 05:53 PM
jeepwhore
That would have nothing to do with the problem. The issue the OP is having is that the shackles are leaning laterally like so /-/......not that they are bowed (-).
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #12 of 17 Old 03-10-2013, 06:01 PM
Jim1611
Jim1611's Avatar
I don't think you've done anything wrong. What I notice is that the ends of the shackles are drawn in more than the center. I've seen this is some stock hangers and some springs, they're actually narrower than the center brace. If you're careful you can grind the center brace off a bit to take care of that problem.
The lean could be several things. Several customers have had that and found that the hanger itself was not sitting on the frame flat or that the frame was bent where the hanger bolts on. That's pretty normal. Hard to fix right though. Another thing to try, as has been mentioned, is to loosen the u-bolts and see if the weight of the CJ will settle them onto place. You may even need to push or pull the spring into alignment.
Another thing that is common is that the hanger itself is twisted. This seems to be the most common. New hangers are the fix for this, not new factory ones though and there's some good aftermarket ones being made too. In going back and looking at the pictures some more I think the springs need moved towards the center of the axle to better align things. I'd try that first. You have any long clamps that would reach from each spring to the other? You won't be able to move them much because of the spring pack bolts that extend into the spring perches but there might be enough play there to help the problem. It won't take much there to make a bigger difference at the end of the spring. Springs can twist too. Oh and take a tape measure and measure the outside distance on the springs where they mount of the stationary hangers then check at the spring perch and the then the shackle end of the spring. All three should be the same and from the pictures you post they don't appear to be.
Hope that's helpful
Jim
Jim1611 is offline
post #13 of 17 Old 03-10-2013, 06:01 PM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ6
If you think that is not straight, just wait till you're flexing on the trail haha. Yeah I can see where the one side is kicked out more than the other. Thats caused by either a shackle twisted, or spring perches too far apart - they they kick outboard on the leaf spring end. I see you tightened down the leaf spring side a little too much on both. Oh well, check your shackle mount for any issues and if all is well then don't even worry about it - non issue. Actually it looks like a fairly decent setup they sold you. The nylon locking nuts will help keep every thing together.
I went with good ole rubber bushing instead of poly. Rubber gives, poly don't. I want as much flex as I can get, even at the expense of having to replace the rubber bushings more frequently - they don't last as long as poly. I'm going for max flex. It all depends on what you are wanting out of your rig.
TIPPEDITOVER is offline
post #14 of 17 Old 03-10-2013, 07:15 PM Thread Starter
10129
So I took the center bolts and sleeves out and retorqued the ends. Then I went for a short drive and found a hill I could flex it on in both directions. i also loosened all the shackle bolts and used a ratchet strap to pull the springs together just a hair. I retorqued everything leaving out the center bolts and it looks like they have straightened up some. i reinstalled the center bolts and sleeves and retorqued everything. We've got a trail ride this Sunday that'll really break them in so I'll look at how they are lining up after that.
Thanks for all the suggestions guys, I'll keep you posted.
1981 Jeep CJ7
10129 is offline
post #15 of 17 Old 03-10-2013, 07:35 PM
zillla
1930 VJ
Looks bowed to me..
Pull my finger
zillla is offline
