New roll bar additions. - JeepForum.com
post #1 of 9 Old 08-20-2013, 04:03 PM Thread Starter
twoleos617
... I mean sway bar
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #2 of 9 Old 08-20-2013, 05:56 PM
LumpyGrits
Took mine OFF the day I drove it home, over 28+ years ago.
Don't miss it one dang bit.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 9 Old 08-20-2013, 09:37 PM
82JeepCJ7
1982 CJ7
Mine is hanging on the shop wall.. Don't need it.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 9 Old 08-20-2013, 10:04 PM Thread Starter
twoleos617
I've had some pretty bad steering issues and have replaced the Entire system except the pump. This was a last resort. Low and behold, it helped a ton! I've had the sway bar off for years and believed that body roll never really played a part in the slightest. I was wrong. Now I'm more stable over bumps and with compounding counter steering issues. Plus in 2 minutes I'm disconnected and right back to full articulation off road.
Still have a little slop in the steering wheel which ill have to work out. That part has me frustrated a little.
Mike D.
post #5 of 9 Old 08-21-2013, 02:01 AM
7179CJ5
1979 CJ5
I also put a sway bar on my '79, it was the missing piece of the puzzle.
The slop in your wheel, have you replaced your steering shaft with a HD one?
7179CJ5 is offline
post #6 of 9 Old 08-21-2013, 05:44 AM Thread Starter
twoleos617
No but I rebuild both ends with all new parts and replaced the lower bearing in the column.
Mike D.
post #7 of 9 Old 08-21-2013, 06:00 AM
7179CJ5
1979 CJ5
Depending on what size tires you are running it is recommended that you replace the steering shaft with a HD one. The original shaft was designed to accommodate the oversize tires and the impact of bumps ect..
7179CJ5 is offline
post #8 of 9 Old 08-21-2013, 06:33 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Replies seem to be 50/50, here....
I still have mine on, but am wondering why.
I'm running a 4" lift with 35's and have to wonder how hairy it would be on pavement without it.
It definitely has to be disconnected for any decent wheeling....
2Xtreme is offline
post #9 of 9 Old 08-21-2013, 08:08 AM
skizriz
1978 CJ7
I often Drive mine home unhooked If Its Muddy. Its not too bad If you dont make sudden movements. Definite improvement on a dd at highway speeds though.
The stiffer the springs, the less Its needed.
skizriz is offline
