#16 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Just an observation, you only have half the body mounts showing, there are galvanized inserts that go in the mount centers so when you bolt it the washers bottom out on this sleeve so the poly part is 'captured' by the washers and sleeve making an up and down shock absorber. This prevents overcompression and blowing out of the mounts.
Check the third part down on this page: Body Mounts & Lifts - Quadratec
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#17 |
lol - I was just looking at those last night - thanks. Wasn't 100% sure if I needed them. I used the black with hardner on the frame as well - was in a hurry cause temps where dropping so it isn't perfect. This weekend is going to be nice to I will make sure to follow the directions to the "T". It does appear to be more resistant to scuffing and scratches - has a nice shine to it as well. Though hard to compare since I haven't used just the paint without hardner.
Not too much stuff - the dang garage keeps shrinking on me. |
#18 |
Looking at the rubber body mounts - they don't have the built in sleeve like the poly ones do. So would a person still need those inserts on the poly bushings?
#19 |
Hey man, great build. Kinda nice seeing others go through the same fun that I did! Take a look through my build, I did the YJ tub swap, had to rebuild the body mounts, as well as other frame portions, and stretched my rear end and comp cut on my 79 CJ7. Went with XJ springs in the rear for a good stretch. Been happy with the way it looks thus far, but haven't been able to flex it out off road just yet. Build looks great though! I got a little stalled on mine when I ran out of big stuff to do, so please keep it going and don't stop until you are done! BTW...what are your plans with the burnt center console from the YJ?
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!! Build Thread: 1979 CJ7 Blue Jeep
#20 |
Hey - yeah I read through your build thread awhile back when I was working one of my 12hr night rotations. I thought about the XJ rears, but decided to stick with waggy rears since its less modifications for now...... Sucks - I got a set of waggy fronts for free, but one is messed up, and now the waggy I bought they are sagging real bad now too. Probably end up buying a new set of 44044 waggy's soon (actually once the buyer comes and picks up the remainder of my waggy donor rig). Been pricing out my next items - and good god, I hope I win the lotto soon.......
You probably don't want the center console (if thats what you are inquiring about). The top hinges are very tight (could be sprayed and freed), but the bottom is rusted out. If that don't deter ya, heck you can have it - lol. If it weren't for getting plates and destroying my polaris radiator I'ld have about 1k in "jeep mod money".. |
#21 | |
Off Road Forever
The poly mounts I put in back in 2000 plain, like yours, thinking the 'built in' sleeves were proper and figured on reusing them last winter when I put a new frame in. Only 2 were salvageable, the rest had overcompressed and blown out. They need the steel inserts to be structurally complete.
#22 |
Got the front of the frame painted, and been sandblasting more parts. Now comes the fun part, I have no more "stuff sold" money, and have to start dipping into my own pocket book - lol. Going to search for my tranny mount on my next off days, and need to buy complete fuel and brake lines.
#23 |
Off Road Forever
I found the link to the body mount kit I used:
Original Replacement Parts 5462446K - Body Mounting Kit for 79-86 CJ-5, CJ-7 & CJ-8 - Quadratec
#24 |
NOT a Web Wheeler
I should have gone this route myself, I wanted a V8 and originally went for a SBC and changed my mind and picked up a 258. A Waggie/Chero/J10-J20 is probably the most economical way to get a V8 in a CJ if it was not orignally a 304.
Great job on the build!
1983 CJ-7, 258, T177, D300, 3.54’s and 32” KM2’s Many thanks to those with contributions to my build: twoleos617, Jim1611, Yellow85CJ, kickingprop, CJnPA, Fatman, Grewel, -boom and VACJ7...oh crap, and EXPOSED too!!! Money Pit >>>http://www.jeepforum.com/forum/f8/daves-83-cj7-build-891652/ ...a jeep ensures you don't have a drinking, drug or woman problem: always dirty, broke and tired. "ACAD_Cowboy" |
#25 |
lol - it gets frustrating at times - one step foward, two steps back kinda stuff. I won't lie, I've debated selling and looking for a more complete, or even better, a running CJ7......
Well ordered the following: MORE motor mounts Offy 4 barrel intake Also buying another D300 tcase and tf999 - found out these past days off that my D300 is siezed up either on the input shaft or the intermediate shaft. Thanks for all the comments and help.... |
#26 |
That tractor paint is some awesome stuff! I had some stuff for almost 30 a qt and the tractor paint is 9. The tractor paint is much more shiny and durable then the expensive stuff. If you dont use the hardener though, it will take 8+ hours to dry.
#27 |
New intake here and the following day the MORE motor mounts came - woohoo..... Shopping for carb now, and hopefully by christmas I can get all new fuel lines and brake lines.
#28 |
Well holiday spending has put an extreme slow down on the jeep project. Here's some update - sorry no pics at this time
![]() Picked up TF999 that was ill, but came with a good d300 tcase. Got my tranny mount now too ..... Am getting some stuff for christmas as well:- Twin stick for my D300 - New poly bushing for my t-case - D300 gasket kit - got a few of the above mentioned metal sleeves for my body mounts Picked up this gem at an auction: ![]() Only down fall is the axles are NT - but appears they both have been redone alittle. Has brand new quadratech stainless brake lines (will be using those), new gas tank and skid, and the tire are new (selling to my dad). Since the weather is now cold - can't really paint anything (very minimal heat in the shop), so the plan is to assembly my stuff to see what else I need, and how it looks. Still need fuel lines, and my waggy springs. Got a lead on some mildly built D44 with 4.88s too.... |
#29 |
Looking good. Keep it up.
Seems like everyday is a Monday. 77' CJ-7 84' CJ-7 83' Chevy K10 |
#30 |
Okay here is the tenative winter plan:
1. Install my christmas gifts 2. need a new fuel line: tank to pump 3. Purchase 2 44044 waggy springs for rear and install 4. Reinstall gas tank 5. Redo rear brake line (76-80 line shorter and terminates at different cross memeber) 6. Finish quick sand of engine block / oil pan, etc 7. Install D300 twin stick and remount tcase to tranny a)install tf999 mount to 727 b)install poly bushing 9. Mount tranny/tcase to motor an secure to mounts 10. Install tub and body lift 11. Install windshield / frame 12. Fit front rollcage hoop 13. Interior parts - got to go through my boxes of parts to see what is needed. a)install and wire dash b)steering c)tranny shifter (not sure which route yet) d)wiring ![]() Hopefully this gets me to spring, or springish - lol. Also hoping to be able to fire up motor, so guess I should add radiator to my list as well. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
