New project - 86 CJ7 - Page 4 - JeepForum.com
post #46 of 89 Old 07-02-2013, 08:40 AM
dsemar
Lovin' it! Can't wait to get to the point you are at. Thanks for the inspiration to keep going!
dsemar is offline
post #47 of 89 Old 07-07-2013, 06:41 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Finally some real pictures of the Jeep out of the garage. ALMOST ready for reg and inspection, all lights are sorted out, except the brake switch needs to be adjusted or moved because the pedal doesn't come up enough to disengage the light. The horn also needs trouble shooting (it works direct to battery, so I think the steering wheel switch is dead). From there I have a handful of small things to wrap up light rear seat install, glovebox lock, soft top install, new headlights, etc. Goal is to get it road legal and wrap these other things up over time.
2013-07-06 20.03.44.jpg   2013-07-06 20.03.54.jpg   2013-07-06 20.04.02.jpg   2013-07-06 20.04.33.jpg
2015 JKU - 6m
Jeeprage is offline
post #48 of 89 Old 07-07-2013, 10:08 AM
JrTjK
1978 FSJ Wagoneer
Looks great! Can't wait to see it driving around. Great job bringing it back to life!!
Hope the fam is well.
JrTjK is offline
post #49 of 89 Old 07-09-2013, 08:39 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Brake lights work, reverse lights work, horn sporadically works, and rear seat is bolted down. I need to chase down why passenger low beam isn't working, and it is off to get it inspected in the next week or two.
2015 JKU - 6m
Jeeprage is offline
post #50 of 89 Old 07-12-2013, 11:59 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Lights fully working and the Jeep is registered. First legal ride to gas station was a success. Looks like oil and temp gauges still need help and speedometer bounces, but I'm a happy guy.
2015 JKU - 6m
Jeeprage is offline
post #51 of 89 Old 07-12-2013, 04:58 PM
dsemar
Congrats man! I'll be right behind ya soon enough.
dsemar is offline
post #52 of 89 Old 07-12-2013, 05:32 PM
jeepers1940
1983 CJ7
That's a great looking Jeep you have there; really like the white color.
jeepers1940 is offline
post #53 of 89 Old 07-12-2013, 05:47 PM
Jeeper44mag
1978 CJ7
PURTY!!! Keep up the good work!
Luis
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #54 of 89 Old 07-12-2013, 06:12 PM
Rodknocker1
It looks like my PCV is off the rear of the engine, which I guess I'll need to Tee off of for my brake vacuum. Any advice or confirmation?
You need manifold vacuum for the brake booster. Should connect under the carb or at the bottom of the carb.
I like the white. Mine was white during the second incarnation.
Rodknocker1 is offline
post #55 of 89 Old 07-13-2013, 06:29 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Thanks, I connected that a while back (although not under the carb). All is well.
Looks like my reverse lights are NOT working since fixing the brake lights. Not sure if it was a fluke, or short that had them light up before. I'll need to sort that out before inspection, but at least it is road legal.
2015 JKU - 6m
Jeeprage is offline
post #56 of 89 Old 07-13-2013, 07:19 AM
Php74
1984 CJ8
Looks great. Love the white.
Php74 is offline
post #57 of 89 Old 07-13-2013, 07:40 AM
Mace350
I am partial to the 86 year as well and I have to say that is one great looking Jeep! Nice Work
Mace350 is offline
post #58 of 89 Old 07-15-2013, 08:24 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Updated shot from this morning! First commute with the CJ to the train station. Dropped it off at the shop for an alignment... its first work done by anyone but me.
Just need to mount lower door hinge so I can figure out the latches, but not too concerned since doors won't be needed much.
Turns out the soft top that came with the Jeep project in a box is in great shape. Score!
2015 JKU - 6m
Jeeprage is offline
post #59 of 89 Old 07-20-2013, 09:42 AM Thread Starter
Jeeprage
Jeeprage's Avatar
No pics, but current status is that I got oil pressure gauge working, fixed stereo power lead to proper circuit, tightened a few bolts, trouble shot reverse lights and ordered new reverse switch.
I finally got brake bias valve connected to wiring harness and the brake light is on now. Looks like it maybe off centered when bleeding. Another thing to deal with after inspection.
2015 JKU - 6m
Jeeprage is offline
post #60 of 89 Old 07-22-2013, 07:30 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Reverse lights are fixed, sort of. Bad connection from engine harness to Trans harness with the return lead connection dead. I jumped it for now and will get it inspected next weekend.
Countless hours spent on that issue.
2015 JKU - 6m
Jeeprage is offline
CJ5 project Matt Jeep CJ Forum 2 07-30-2011 07:37 AM
My First CJ project JeepnBlake Jeep CJ Forum 31 10-25-2009 06:17 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 12:38 PM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 06:53 AM
81 CJ7 Project BeesJeep Jeep CJ Forum 8 12-16-2007 10:08 AM
