New project - 86 CJ7 - Page 2 - JeepForum.com
post #16 of 89 Old 10-30-2012, 02:37 PM
JrTjK
1978 FSJ Wagoneer
Looks great, Hal! Anytime you need to stop on by to compare you're welcome to.
JrTjK is offline
post #17 of 89 Old 10-30-2012, 09:20 PM
ghbatt
Originally Posted by Jeeprage
Progress is being made. My wife snapped this picture the other day, after not having seen "Rubble" herself in months. She had stayed out of the garage.
At the time of this picture I had wire-wheeled the entire frame, axles, skid, POR'ed and top-coated it all, installed new 2.5" suspension and hardware, replaced the fuel tank with new.
Since this picture, I've installed almost all of the new SS brake and fuel lines, replaced fuel hoses, filter, and new fuel filler hoses.
I have new rotors, calipers, and full rear drum kit to install soon (had to wait for hub socket to arrive), new OME shocks, and most importantly... changed direction and ordered a new 4wd Deluxe Fiberglass tub with tailgate cutout that is to be delivered today. (I have the 92 YJ body for sale).
I'm at the point of no return, so I decided to do the glass tub and fenders the first time.
Just a question. Did you por the frame with the transmission and engine in? I am hoping to do that, and I wonder if you have any tips?
Check out my Build
http://www.jeepforum.com/forum/f8/gregs-86-cj7-build-thread-1421551/
ghbatt is offline
post #18 of 89 Old 10-31-2012, 05:00 AM Thread Starter
Jeeprage
Jeeprage's Avatar
Yes, I left them in place. I haven't heard it run yet, but it has aluminum valve cover and Holley carb, so it has been tinkered with in the past. As for tips, just take your time. I used the wire wheel on all of it except the engine. I'll paint the engine when I eventually pull or replace it, but want to get it driving first and see what I'm dealing with.
I did 2 coats of POR, then top coated with rustoleum spray paint. I covered the new gas tank, skid, axles, etc.
2015 JKU - 6m
Jeeprage is offline
post #19 of 89 Old 04-01-2013, 05:51 AM Thread Starter
Jeeprage
Jeeprage's Avatar
House is done, twins have not yet arrived, so I resumed the Jeep work last week.
I've since:
Installed cooling system (radiator, all new hoses, thermostat)
Installed new belts (alt and power steering)
FINALLY bolted fenders to grill
Installed/drilled hood catch hardware
Bought a battery (I can dream)
Connected engine side harness to interior, and pretty much where I'm stuck right now.
The Jeep has a Holley, so I am safe on running a computer, but curious if I need ANY of the harness that the computer connects to. Almost every end is labeled "Not used" or "Not needed" by the previous owner.
Here is my separate post regarding wiring: http://www.jeepforum.com/forum/f8/an...olley-1501758/ There was a lot of confusion having been given multiple harnesses from both CJs and a YJ.
2015 JKU - 6m
Jeeprage is offline
post #20 of 89 Old 04-02-2013, 06:15 PM Thread Starter
Jeeprage
Jeeprage's Avatar
4/2/13 - It fired up and runs! New fuel pump on, and I primed the pump from a cup of gas, but it fired up.
Squeaky belt, which I guess I didn't tighten enough when I put the new belts on, and I still need to install lower radiator hose and fill with water. I'll aim for that this weekend and let it run, warm up, and blow out the cobwebs.
On to the next thing...
2015 JKU - 6m
Jeeprage is offline
post #21 of 89 Old 04-19-2013, 04:01 AM Thread Starter
Jeeprage
Jeeprage's Avatar
It was like Christmas in April yesterday. New seats, hinges, shifter boots and fender flares arrived. A few more things outstanding, but in good shape. forumrunner_20130419_060010.jpg
A shot of the Jeep after moving, before i started tearing it down to prime.
2015 JKU - 6m
Jeeprage is offline
post #22 of 89 Old 04-19-2013, 11:05 AM
Renegade82
1982 CJ7
Great time of the year to be finishing it up. Looks good. Question. I see you used the stock shackles with your new springs. What bushings did you have to use to make them work? The stock bushings are rounded on the ends and have a metal sleeve. Poly bushings have thick, flat shoulders and may or may not use a sleeve. Will poly bushings work with the stock shackles?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #23 of 89 Old 04-21-2013, 12:22 PM Thread Starter
Jeeprage
Jeeprage's Avatar
I used the poly bushings that I bought as part of a full poly set. I ended up only using about half the set since I went with a fiberglass body and couldn't use the body mounts.
I kept the stock rubber bushings in a drawer in case I find a reason to swap back out after I get this thing on the road.
It is a great time to be wrapping it up, but I'm afraid it won't be done "in time". I have less than 2 months left until twins arrive.
2015 JKU - 6m
Jeeprage is offline
post #24 of 89 Old 04-21-2013, 06:13 PM
firzout
1982 CJ8
Looks like its coming along nicely...
firzout is offline
post #25 of 89 Old 04-21-2013, 08:30 PM
jeepers1940
1983 CJ7
The POR and paint on your frame looks great; is there a lot of prep before applying the POR?
jeepers1940 is offline
post #26 of 89 Old 04-22-2013, 06:45 AM Thread Starter
Jeeprage
Jeeprage's Avatar
I wire wheeled the entire frame, used POR's metal prep, 2 coats of POR, 2 coats of Rustoleum top coat.
The metal prep brushes on over clean and lightly rusted metal and turns it white. I top-coated the POR with Rustoleum because POR does not hold up to UV exposure, and it really made it pop.
I don't plan to pull the body off again any time soon, so I replace entire fuel and brake systems, tanks too, while I was at it.
2015 JKU - 6m
Jeeprage is offline
post #27 of 89 Old 05-05-2013, 04:22 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Got seat brackets cleaned up and painted, seats and new slider mounted to them, and put in place.
All lights were drilled for in the glass body, some wiring under hood cleaned up, washer tank mounted, and a handful of other small things. Fender flares drilled and test fit as well.
Now on to the fun stuff.. stripping the exterior clean and doing some body clean up. Lots of fiberglass junk to sand off the body, and doing my best at bondo/primer to fill in rock chips and small dents on the hood, grill, and tail gate. My new windshield frame came as well... with a big dent in it. Got to call Quadratec tomorrow and get them to send another.
2015 JKU - 6m
Jeeprage is offline
post #28 of 89 Old 05-09-2013, 12:20 PM Thread Starter
Jeeprage
Jeeprage's Avatar
Purchased paint and primer this morning. I'll be spending this weekend washing it up, doing rough sanding, and hopefully masking it all off.
2015 JKU - 6m
Jeeprage is offline
post #29 of 89 Old 05-09-2013, 06:32 PM
contdevelop
Great progress!
contdevelop is offline
post #30 of 89 Old 05-18-2013, 02:46 PM Thread Starter
Jeeprage
Jeeprage's Avatar
I was able to get things masked and prepped, and got 2 coats of primer done today. Not bad for the first time using a spray gone. The goal will be to to light sanding and a 3rd coat tomorrow, then wet sand it all down during the week with a goal of spraying base coat next weekend.
Clock is ticking, out babies will be here within weeks. The Jeep certainly won't be "done", but I hope to get the painting out of the way and start reattaching exterior parts. Seats and interior will likely be a while.
2015 JKU - 6m
Jeeprage is offline
CJ5 project Matt Jeep CJ Forum 2 07-30-2011 06:37 AM
My First CJ project JeepnBlake Jeep CJ Forum 31 10-25-2009 05:17 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
81 CJ7 Project BeesJeep Jeep CJ Forum 8 12-16-2007 09:08 AM
