New member..Ive got a question?? - JeepForum.com
post #1 of 3 Old 12-11-2002, 06:38 PM Thread Starter
cruzman8
Hello Everyone.Great board here.My steering shaft needs to be a little longer,someone told me they are made so you can extend them .Is this true and how do you do it?Thanks
cruzman8 is offline
post #2 of 3 Old 12-11-2002, 08:00 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hey welcome to the board. You should be able to pull it apart at the slipjoint. Might have to heat it with a propane torch a bit. Make sure you leave enough engaged (at least 2" or so) so that it doesn't pull apart going down the road
BESRK is offline
post #3 of 3 Old 12-11-2002, 08:00 PM
MudLover
MudLover's Avatar
Anything can be "extended", you just need enough duct tape. Why do you need to extend it? Body Lift? I know there are kits you can buy to fix that, but I thought they came with the lift. You can also buy a whole new one. I know Borgeson makes a "Heavy Duty Steering Shaft" so check out www.borgeson.com I have also heard of "collapsable" steering shafts. Can't remember who makes them though.
Good Luck,
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
Soft spot at rear cross member-Repair Question jpd1899 Jeep CJ Forum 1 01-24-2010 03:24 PM
new member with engine swap question Dufftrucks Jeep CJ Forum 1 11-28-2009 09:01 AM
New member saying hello and with a question crawdad Jeep CJ Forum 6 04-27-2008 06:05 PM
New member with speedometer cable question Jeepy-V Jeep CJ Forum 2 10-19-2005 03:54 PM
New Member 78 CJ7(Question) jeep1978 Jeep CJ Forum 3 02-12-2005 08:57 PM
