New member with a few questions - JeepForum.com
post #1 of 7 Old 10-18-2013, 10:08 AM Thread Starter
gravydavey
1977 CJ5
So I picked up an unmolested 77 CJ5 that came from Nevada.
The engine has been replaced at one time or another it has a slight ticking noise sounds like a rocker arm are these known for wear?
The trans is a 3spd I think it is suppose to be a 4spd am I correct?
Need to fix the speedo dash lights fuel tank leaks around the neck and the fuel gauge doesn't work.
gravydavey is offline
post #2 of 7 Old 10-18-2013, 11:11 AM
texasdave
texasdave's Avatar
1980 CJ7
Sweet! Take a long handled screwdriver and use it as a stethoscope. That will help to isolate the noise. Your vin number would tell the xnsmsn I would say it is stock some came with a 3 speed warner t-15. Search the forum for John Strenk he has a lot of good posts about wiring and fixing gauges. Is it the tank itself or the filler hose?
Welcome aboard there is a lot of good information contained in this forum and many people willing to help. One tip be as specific as possible i.e. engine size and type if an engine question, drive train type or manufacturer etc.
texasdave is offline
post #3 of 7 Old 10-18-2013, 12:31 PM Thread Starter
gravydavey
1977 CJ5
Its a 258 six
The tank is leaking where the neck is welded to the tank.
Will get into it this winter.
post #4 of 7 Old 10-18-2013, 01:28 PM
hp_lovecraft
1981 CJ5
The 3-speed was standard, while the 4-speed (3+1) was optional. I had the 3-speed for years on one of my jeeps, and I never had an issue with it.
Bad fuel guages are a problem we all deal with. Could be a bad guage. Could be a bad sender. Could be a bad ground, or any number of wiring issues. John Strenk has a whole website with problem-solving for the guages. The only crappy part is that the aftermarket "oem" options are even worse quality then the factory.
That said, if you are going to drop your tank for a repair/replace, thats a good time to swap in a new sender. Dropping the tank is no fun. I've done it about 5 times in the last 4 years (3 to replace the sender, and 2 to fix a leak).
hp_lovecraft is offline
post #5 of 7 Old 10-18-2013, 01:57 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Nice! Keep her in good shape! That's a beauty.
X2 on that. If you have to drop the tank, be sure to do all the work back there while it's out. Of course the sender is a likely candidate for replacement. You might also consider running a dedicated ground wire for the sender if you can't otherwise get a good ground. If the tank is leaking or you're getting clogged fuel filters, you might consider a tank replacement, or just cleaning out the current tank while you have it down.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is online now
post #6 of 7 Old 10-18-2013, 03:12 PM Thread Starter
gravydavey
1977 CJ5
Thanks for the info the trans works great just a huge ratio change from second to third gear.
And the tank definitely has to come out
post #7 of 7 Old 10-18-2013, 03:40 PM
Tigerjeep79
1979 CJ7
Dropping the tank isn't too terrible, as long as you make sure it's empty first. I learned this lesson the hard way. Nice Jeep by the way! Nevada tends to be nice to Jeeps. Mine's been in Las Vegas its whole life, so there is zero rust.
Tigerjeep79 is offline
