New Mean Green starter won't turn Jeep over?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > New Mean Green starter won't turn Jeep over??
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 06-27-2013, 03:44 PM   #1
sarfu
1974 CJ5
Hi,
Just installed a Mean Green starter on my 74 CJ5, and all I get when I turn the key is a click, checked my wiring ( I have a dedicated ground to one of the starter mounting bolts and the pos wire is going from the solenoid to the starter) new cables.
My old starter fires the jeep up with no problem, could I have a bad starter out of the box and how would I test it?
Thanks for any input.
sarfu is offline   Reply With Quote Quick reply to this message
Unread 06-27-2013, 03:51 PM   #2
LumpyGrits
To test......Put old starter back in an see if she starts.
Those MG starters ain't worth it IMHO.
LG
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 06-27-2013, 04:39 PM   #3
Cherokeester
1980 CJ7
Bad engine ground I would guess if the starter is good.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline   Reply With Quote Quick reply to this message
Unread 06-27-2013, 05:03 PM   #4
fuzz401
1978 CJ7
does the starter have 2 post on it if it does jumper the 2 together I had to do it with my power master starter
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
http://img2.photobucket.com/albums/v...slideshow=true
http://photobucket.com/albums/v31/fu...slideshow=true
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2013, 07:53 PM   #5
sarfu
1974 CJ5
got her going thanks guys.
Removed the jumper wire when I installed it, had to reinstall jumper.
