New to me 78 CJ 5 - Page 2 - JeepForum.com
post #16 of 37 Old 06-08-2013, 09:03 PM
robs7
1983 CJ7
Originally Posted by dison001
Well, its been awhile since I updated. The painless is partially done. Under the dash is right. Little man and I worked under the hood today. Awesome day. About a third of the way done under the hood with wiring.
Sounds like a good day! Little man helps me a lot too. Productivity tends to go down but enjoyment tends to go up! Rob
robs7 is offline
post #17 of 37 Old 06-09-2013, 03:34 PM
turbogus
1978 CJ5
That's great to hear!
I'm still ruminating about the ongoing wiring project(s) on 'Black Betty', most of which is upgrading the wiring connectors from 18 and 16 gauge to 10. Gives me great practice for my soldering skills.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #18 of 37 Old 06-22-2013, 07:33 PM Thread Starter
dison001
Has anyone here thays done the painless kit had to relocate parts to avoid cutting up the new harness? My ignition box is on the drivers side, but seems that it would be easier to move it to the passengers side than to cut up the new harness. Opinions?
dison001 is offline
post #19 of 37 Old 06-22-2013, 08:44 PM
LeePrather
1978 CJ5
I finished up a painless wire on my 78 cj5 304 within the past couple months. If you have any specific questions, there are some areas that are gonna hang you up a little probably. The rear harness colors don't match up with the light harness, fuses are gonna blow (most frequently the coil 30a and the gauges 10a or radio 10a. Always check your fuses first if it isn't working. Front harness was easy, back harness was easy other than figuring out the colors, I customized the dash stuff (you will probably pull out a LOT of extra wires) but it was easy, the engine was the hardest but it wasn't bad. You will have a lot of extra length on every wire and I went back and cut them much shorter because they really get messy
LeePrather is offline
post #20 of 37 Old 06-22-2013, 08:50 PM Thread Starter
dison001
Thanks. I really need to finish this up.
dison001 is offline
post #21 of 37 Old 06-27-2013, 03:19 PM Thread Starter
dison001
Ok, another question. I have a Delco internally regulated alternator. I need to make the connections to it. My original plug is not salvageable. Any suggestions on either getting a new plug, or rigging it correctly (if there is such a thing.)
Thanks in advance
dison001 is offline
post #22 of 37 Old 06-27-2013, 03:50 PM
lucdog
lucdog's Avatar
1980 CJ5
Thanks in advance
I've seen the alt. connections at the electrical section of O'Reillys auto parts.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #23 of 37 Old 06-27-2013, 04:12 PM Thread Starter
dison001
No Oreileys here. Called my go to NAPA with no success.
dison001 is offline
post #24 of 37 Old 06-27-2013, 04:52 PM
lucdog
lucdog's Avatar
1980 CJ5
Possibly auto zone or advance auto, or on line. Enter your zip code, pick a store . A junk yard is also a possibility.
http://m.oreillyauto.com/mt/www.orei...1497&ppt=C0330
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #25 of 37 Old 06-27-2013, 05:05 PM Thread Starter
dison001
Thanks guys. I have both close. Will have to go in and look as their employees are simply cashiers.
dison001 is offline
post #26 of 37 Old 07-06-2013, 11:46 AM Thread Starter
dison001
Ok, next question for you guys. I broke the hook up stud off the alternator. Any suggestions for a good quick fix?
dison001 is offline
post #27 of 37 Old 07-06-2013, 07:51 PM
Blutarsky
Blutarsky's Avatar
1982 CJ7
Was this solved?
1982 CJ-7
My build thread ruined by the fine folks at photobucket, repaired by a lot of tedious hours.
Blutarsky is offline
post #28 of 37 Old 07-14-2013, 10:27 AM Thread Starter
dison001
Yes. Sorry it took so long for the reply.
dison001 is offline
post #29 of 37 Old 07-14-2013, 10:28 AM Thread Starter
dison001
I found a perfect connector in a stash of parts I have. Just spliced it in.
dison001 is offline
post #30 of 37 Old 07-27-2013, 09:26 PM Thread Starter
dison001
Anybody know if theres any electrical connection to the carb in my Jeep? Its a 78 cj5 with the 304, and I believe a Motorcraft 2100 carb. If so, wheres it hook up?
Thanks guys
dison001 is offline
