new lines-6 cyl or v-8? - JeepForum.com
post #1 of 3 Old 10-19-2009, 08:06 PM Thread Starter
southshore30
1982 CJ7
I'm ordering some new fuel lines for my cj 7. I am going to be starting a build from the frame up and will be swapping in a 350 chevy. what lines should i order? On 4wd hardware there are 6cyl and cyl fuel lines availabe, i'm assuming they are just bent a little differently and it is not different diameters. anybody know more?
southshore30 is offline
post #2 of 3 Old 10-19-2009, 08:37 PM
bleoh
The 6cy mechanical fuel pump is on the right side of the engine and the V8 is on the left side. The fuel lines run up the right side of the frame so the v8 lines go all the way to the front cross member and cut over to the left side.
bleoh is offline
post #3 of 3 Old 10-19-2009, 08:59 PM Thread Starter
southshore30
1982 CJ7
Thanks! sounds like I will just get the 6cyl lines since the 350's fuel pump is on the passenger side like the 6cyl. Still may go with a electric fuel pump but cross that path when I get there
Vac Lines For 86 Cj RICKIE Jeep CJ Forum 2 12-18-2008 11:15 PM
Weber 34 conv, nutter, Vacuum lines / Fuel lines valkadesh Jeep CJ Forum 29 06-11-2007 09:21 AM
Running auto trans lines...use braided or hard lines? Pacfanweb Jeep CJ Forum 7 08-15-2006 10:07 PM
Vac. Lines CorryDiller Jeep CJ Forum 4 08-09-2004 12:14 PM
brake lines, gas lines, which order certifiablejeep Jeep CJ Forum 6 06-30-2003 04:03 AM
