New lift question - shackle angle question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > New lift question - shackle angle question
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 10-09-2009, 07:24 AM   #1
*Thunder
1979 CJ7
I had a Black Diamond 3 inch lift installed on my 79 CJ7 in April of this year. Everything was replaced - springs, shackles, bushings, shocks, U-bolts and it has not been driven a whole lot this year - been working on other things on it.
My question is, and I know a picture would help alot, but the rear shackles seem to be leaning out alot more than the front shackles. The front shackles have a slight angle to them which is what I would expect. The rear shackles are pushed out quite a bit more than the fronts, I would say from memory maybe at a 45 degree angle.
Does that seem right that the rear shackles would be pushed out more than the front?
I will try to post some pics tonight.
*Thunder is offline   Reply With Quote
Unread 10-09-2009, 07:47 AM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If the Jeep itself sits pretty level, I wouldn't worry about it. Basically, you want the shackles to be slightly angled outward but not bottom out on the frame at full compression.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 10-09-2009, 08:53 AM   #3
78treehugger
1980 CJ7
I have the BD 3" as well. I replaced my rears because they were sagging terribly after 2 years of use. I had the new set on less than a month and are now sagging. The shackle mount part of the spring is less than 1/4" away from the hanger itself. I called Black Diamond/Superlift and they agreed to send me new springs under warranty. I just had to go through the place I bought the lift from (4 Wheel Parts). On this second occasion I talked with 4 Wheel Parts and they are ordering a set of YJ rears since they are supposedly a little HD and 1/2" higher lift. I am hoping they are just a bolt and go with no issues. I have read that some YJ rears are much longer than the CJ rears, but that seems to vary by manufacturer. Hopefully they'll be in today.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
http://emptypocketsoffroad.org/
78treehugger is offline   Reply With Quote
