New Leaf Springs? - JeepForum.com
post #1 of 11 Old 07-04-2009, 01:45 PM Thread Starter
jeeprookie47
1966 CJ5
New Leaf Springs?
Im working on a 1966 CJ5 and in my opinion (im not a car expert) the leaf springs probably need to get replaced. Is this true, should I get new ones? Also, those are 5 leaf, could I replace them with 9 leaf, and if so what are the advantages/disadvantages?
jeeprookie47 is offline
post #2 of 11 Old 07-04-2009, 02:37 PM
thantos858
1974 CJ5
You can take them to a shop and have them rearched and fixed if theres any problems. Running more springs means a harder ride. I personally don't see anything really wrong with those but I could be wrong. If your wanting new springs order a OEM replacement set from one of the manufactures that do lifts.
thantos858 is offline
post #3 of 11 Old 07-04-2009, 02:44 PM
nshefbuch
1982 CJ7
those leafs look pretty good. only problem is having only 5 leafs. i have a 62 cj5 and wish mine looked that good. my leafs are flat.
nshefbuch is offline
post #4 of 11 Old 07-04-2009, 02:51 PM Thread Starter
jeeprookie47
1966 CJ5
Thanks a lot guys. I thought that the bottom 2 leafs, being flat might be a problem. I will probably just wire wheel them, and then paint them. Thanks for the advice.
post #5 of 11 Old 07-04-2009, 04:45 PM Thread Starter
jeeprookie47
1966 CJ5
the only problem is I have 5 leaves? Do I want more or less leaves? I would think that if I bought 9 leaf ones, it would make for a better ride. Is this true?
From what thantos says, it would make for a harder ride. Sorry I dont know all about this, Im only 16.
post #6 of 11 Old 07-04-2009, 04:51 PM
BriansCJ
1994 XJ Cherokee
More leaves would make for a harder ride. If you want a stronger packwith better ride, add one right under the main leaf and take the last, shortest one out.
Your pack looks fine, I would disassemble it wire wheel it and paint it. Maby some new spring retaining clip things.
Lots of research is your friend.
Brian
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #7 of 11 Old 07-04-2009, 09:09 PM
nshefbuch
1982 CJ7
i'd run those leafs you have, only way i would upgrade to 9 leafs is if you came across a set free or almost free. i run 9 leafs in a spring over configuration, rides kinda rough but its an old cj. the spring over suspension has softened it up some. you could try upgrading your shocks if you want to change your ride quality. i used skyjacker shocks, cheap and descent quality.
post #8 of 11 Old 07-06-2009, 06:09 PM
hidesertkid
1974 CJ5
Hey Brian,
Are you saying to soften up the ride with stock springs by removing a leaf? If so can you tell by a photo which to remove? are you good at that kind of thing? and if so I would like to send you a photo of my springs.
Thanks
HighDesertKid
hidesertkid is offline
post #9 of 11 Old 07-07-2009, 09:31 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Nothing jumps out at me from the pictures, but its hard to judge a leaf when its not under load. Do you have pics of the Jeep prior to the leaf pack removal?
The leaf packs themselves may be fine, but you'll want new bushings at the very least. I wouldn't buy 9-leaf packs. If you're going to buy new springs, get an aftermarket set with a little lift.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #10 of 11 Old 07-07-2009, 09:49 AM
CSP
Not necessarily. It depends also on the thickness of each leaf and the spring rate. Both National spring and Alcan make very compliant, smooth riding springs with multiple leaf packs. The key is thin leaves.
CSP is offline
post #11 of 11 Old 07-07-2009, 08:46 PM Thread Starter
jeeprookie47
1966 CJ5
Thanks everyone,
And I think I do have a picture of the leafs under load. I will try to upload it tomorrow
Leaf Springs Help rrtex1 Jeep CJ Forum 21 12-10-2009 02:16 PM
cj5 leaf springs vs. cj7 leaf springs tcwinters5 Jeep CJ Forum 2 12-07-2009 07:06 PM
Leaf Springs rrtex1 Jeep CJ Forum 2 12-07-2009 01:35 PM
leaf springs garethevans Jeep CJ Forum 10 10-04-2007 11:11 AM
CJ leaf springs lorenwalding Jeep CJ Forum 6 10-28-2004 10:44 AM
