Quantcast New To The Jeep Thing, A Few Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > New To The Jeep Thing, A Few Questions
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 03-14-2008, 09:41 PM   #1
Darryl
1978 CJ7
The 78 CJ7 I just bought is pretty much stock and I want to keep it that way.
However, the guy I bought it from said that it should have new spring shackles that will lengthen it slightly, because the suspension wants to shift back and forth when accelerating or hard braking.
Does this sound right?
If so, what are these called and who makes them?
Thanks in advance.
Darryl is offline   Reply With Quote
Old 03-15-2008, 09:45 AM   #2
NHwheelin
1991 XJ Cherokee
The first thing I would check would be the U-bolts that hold the springs to the axles. i dont think shackles would control to front to rear movement.if you want to buy new shackles I wouldnt go more then 1/2 longer then stock. You can pick stock shackles up at 4wd.com,quadratec.com, most companies carry them and they are pretty inexpensive. But I would definetly check the U-bolts first cause if they are loose our broken then you will have a seriouse problem keeping the axles under it. Good luck on the fix and Welcome to the never ending world of CJ's enjoy the headaches and truimphs.
Kevin
91 XJ Limited (stock for now)
NHwheelin is offline   Reply With Quote
Old 03-15-2008, 10:17 AM   #3
Slawth
Slawth's Avatar
1978 CJ5
Kevin
X2
The guy you bought it from does not sound like he has a clue. I'd go through it and check/ change all the fluids, check the brakes, inspect/ replace the sparkplugs etc...
The End
Slawth is offline   Reply With Quote
Glock Forum
