New Gas Tank Install - SNAP RING!!!!?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > New Gas Tank Install - SNAP RING!!!!??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 03-28-2008, 03:21 PM   #1
CLEMSONTIGER
Tank is all ready to go, can't figure out the best method for turning the new snap ring for the sending unit. When I apply pressure to one of the three "tabs" that should slip under the lip of the tank that the other two pop out. Is there a special tool that applies equal torque like a socket?
'78 CJ7, 304 W/EDELBROCK HEADS AND HOLLEY CARB, T-150, D300, CLEMSON ORANGE PAINTJOB.
CLEMSONTIGER is offline   Reply With Quote
Unread 03-28-2008, 03:51 PM   #2
Bard
Snap ring pliers work the best for them. Other option is to use 2 flat screw drivers, hold 1 hole down and use the other to work the ring into the gap and around. Little bit of pressure, but do not force it too much.
Edit - Sorry, totally missed it the first time, you are referring to the gauge locking ring, it isn't a snap ring, just a 3 sided plate which should slide into the groves, I use 2 screw drivers and get one side almost in and spin it with another screwdriver and a slight tap from a hammer. I also apply some downward pressure to get it to seat correctly. Another tip is to make sure the bottom seal is warm so it compresses when installed. Hope this helps.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Unread 03-28-2008, 04:23 PM   #3
PhatBasturd
Lazay-Lay Bon-Tom Roulay
PhatBasturd's Avatar
1976 CJ7
I used the same method.
New tank so no gas fumes to worry about while tapping on the ring. Correct????
PhatBasturd is online now   Reply With Quote
Unread 03-28-2008, 05:43 PM   #4
bigjoe
1977 CJ7
Tapping on it should not be an issue.
bigjoe is offline   Reply With Quote
Unread 03-28-2008, 10:14 PM   #5
Mr.Crowley
1980 CJ7
the ''Correct'' way to knock that lock ring into place is to use a brass drift or wood dowls..Using a screw driver ''could'' throw off a spark and set the whole tank off into oblivion..But I never had a problem,but was aware of the danger..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Unread 03-29-2008, 07:39 AM   #6
CLEMSONTIGER
Not worried about setting it off, brand new, no gas in it yet.....thanks for all the replies I'll give it a try now with another set of hands to help.
