new fuel sending unit calibration for CJ - JeepForum.com
post #1 of 11 Old 05-09-2008, 01:27 PM Thread Starter
boydog40
I need instructions on how to calibrate a new fuel sending unit for my CJ-5
looked in the archives but found nothing
thanks
boydog40 is offline
post #2 of 11 Old 05-09-2008, 08:26 PM
NHwheelin
1991 XJ Cherokee
I dont know if you can calibrate it. I installed a new unit in my cj7 and didnt even see anyway to calibrate it. I am pretty sure it is "plug and play"
91 XJ Limited (stock for now)
NHwheelin is offline
post #3 of 11 Old 05-09-2008, 08:31 PM
CrazyHorse6
1979 CJ7
I agree- no calibration necessary unless you specifically purchased a sending unit for a different gal size tank than what you have.
CrazyHorse6 is offline
post #4 of 11 Old 05-09-2008, 09:11 PM
illinicj
1979 CJ7
I didn't calibrate mine and it works fine. Although I suppose you could see how it works with your gauge in the high and low positions and bend the arm to get it where you want it. I doubt you'd need to.
illinicj is offline
post #5 of 11 Old 05-10-2008, 04:56 PM Thread Starter
boydog40
ok, well then maybe my gauge is bad because it reads full all the time when power is on
boydog40 is offline
post #6 of 11 Old 05-10-2008, 05:24 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Are you sure the connections are right? If the gauge is moving freely and you can watch it go to "full" when the vehicle turns on, it sounds like it's not getting the correct signal.
http://www.jeeptech.com/electrical/gauges/
Take a look there.. about halfway down the page refers to the fuel gauge.. good luck.
If the resistance falls in this ballpark (depending on how much gas you have in the tank), then the sending unit is fine. If it shows infinitely HIGH resistance, then the sending unit could be bad OR the wire from the tank to the gauge could be open.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #7 of 11 Old 05-10-2008, 06:44 PM
JeepHammer
Running On Empty...
1973 CJ5
Look up user John Strenk, he has a GREAT site on how to mess with CJ gauges!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 11 Old 05-12-2008, 12:14 PM Thread Starter
boydog40
the only connections i disconnected were at the tank, which the gauge now is reading all over the place, never the same anytime I crank it - ground?
boydog40 is offline
post #9 of 11 Old 05-12-2008, 02:58 PM
mmerlina
mmerlina's Avatar
When I was doing my sending unit a local jeep mechanic told me to double check the ground because it's in a bad place and tends to rust over and give funny signals.. so yes it may be a ground..
Mike
1986 Jeep CJ7 (
mmerlina is offline
post #10 of 11 Old 05-13-2008, 09:27 AM Thread Starter
boydog40
thanks will ck the ground, did you just clean your ground connection or run one straight from the battery back?
boydog40 is offline
post #11 of 11 Old 05-13-2008, 10:03 AM
CjinPA
CjinPA's Avatar
If it is reading full all of the time then it is going to ground. If it reads empty then you don't have a ground. If you want to check your gauge take the red wire with the plug on the end of it off of the sending unit, take a piece of wire as a jumper, and run it to a ground (frame). The gauge should go to full. Don't hold it directly to ground for too long or you risk ruining the fuel gauge.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
In Tank Fuel Sending Unit Calibration Crazy_Jeeper_7 Jeep CJ Forum 4 12-23-2009 07:57 PM
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
0-90 Ohm fuel sending unit for a CJ? jfrdog Jeep CJ Forum 0 11-23-2008 01:01 PM
fuel sending unit GO-NOLES84 Jeep CJ Forum 5 11-11-2008 03:52 PM
Fuel Sending Unit collinpyle Jeep CJ Forum 6 03-21-2006 03:01 AM
